四线步进马达如何改编下面程序使其反转?
1113|0
nature0|  楼主 | 2014-11-29 16:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
void Go()
{        char i ,temp;
     //A
    PH1 = 0;  //PH1为0 则A线圈为反向电流
        for(i = 0; i<3; i++)
        {  temp = P1;
           P1 = TableA[i];
           P1 = P1&temp;
           delay(1);
        PH2 = 0;  //PH2为0 则B线圈为反向电流
        I02 = 1;
        I12 = 1;   //输出0
        delay(speed);
        //0
    I01 = 1;  //输出0
        I11 = 1;
        PH2 = 1;  //PH2为1 则B线圈为正电流
        {  temp = P1;
           P1 = TableB[i];
           P1 = P1&temp;
           delay(1);
        delay(speed);
        //B
        PH1 = 1;   //PH1为1 则A线圈为正向电流
        {  temp = P1;
           P1 = TableA[i];
           P1 = P1&temp;
           delay(1);
        PH2 = 1;  //PH2为1 则B线圈为正向电流
        I02 = 1;  //输出0
        I12 = 1;
        delay(speed);
        //0
        I01 = 1;
        I11 = 1;
        {  temp = P1;
           P1 = TableB[i];
           P1 = P1&temp;
           delay(1);
        delay(speed);
