一个msp430f149 的程序,求帮改错
978|13
116910646|  楼主 | 2014-12-25 14:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "io430.h"
#include "io430x14x.h"
void init (void);//初始化
void yalichuanganqiinit();
void yuchuliinit();
void chengzhongjijiaiinit();
void Jianpaninit();
void shumaguanxianshiinit ();
void A/D zhuanhuan();
void BCDmazhuanhuan();
void qingchu();
void qupi();
void leiji();
void duquzhongliang();
void duqudanjia();
void jisuanjine();
void jianpanfenxi();
void xianshizhongliang();
void xianshidanjia();
void xianshijine();
void yuchuliinit()
void Jianpaninit()
void A/Dzhuanhuan()
void qingchu()
void qupi()
void leiji()
void duqudanjia()
void jisuanjine()
void jianpanfenxi()
Void xianshidanjia()
void xianshijine()
void main()
init();
while(1)
yalichuanganqi ();
yuchuli ();
chengzhongjijia();
Jianpan();
shumaguanxianshi ();
void yalichuanganqi ()
A/Dzhuanhuan();
BCDmazhuanhuan();
void yuchuli ()
qingchu();
qupi();
leiji();
void chengzhongjijia()
duquzhongliang();
duqudanjia();
jisuanjine();
void  Jianpan()
jianpanfenxi();
void shumaguanxianshi ()
xianshidanjia();
xianshijine();
qq4988| | 2014-12-25 14:55 | 只看该作者
#include "io430.h"
void yalichuanganqiinit(void);
void yuchuliinit();
void Jianpaninit();
void shumaguanxianshiinit();
void ADzhuanhuan();
void qingchu();
void qupi();
void leiji();
void duqudanjia();
void jisuanjine();
void xianshijine();
void shumaguanxianshi();
void  Jianpan();
void yalichuanganqi();
void yuchuli();
void chengzhongjijia();
void yuchuliinit()
void Jianpaninit()
void ADzhuanhuan()
void qingchu()
void qupi()
void leiji()
void duqudanjia()
void jisuanjine()
void jianpanfenxi()
void xianshijine()
void main()
// init();
  while(1)
    yalichuanganqi();
    yuchuli();
    chengzhongjijia();
    Jianpan();
    shumaguanxianshi();
ADzhuanhuan();
BCDmazhuanhuan();
void yuchuli()
qingchu();
qupi();
leiji();
duquzhongliang();
duqudanjia();
jisuanjine();
void  Jianpan()
jianpanfenxi();
xianshidanjia();
xianshijine();
全是语法错误
116910646|  楼主 | 2014-12-25 15:01 | 只看该作者
qq4988 发表于 2014-12-25 14:55
#include "io430.h"
能帮修改下么
qq4988| | 2014-12-25 15:01 | 只看该作者
116910646 发表于 2014-12-25 15:01
能帮修改下么
那就是改好的
116910646|  楼主 | 2014-12-25 15:07 | 只看该作者
qq4988 发表于 2014-12-25 15:01
那就是改好的
好吧
你知道为什么 我用IAR 生成 HEX 文件为什么只有 1KB么
qq4988| | 2014-12-25 15:11 | 只看该作者
116910646 发表于 2014-12-25 15:07
好吧
你这里面只是声明一个程序,并没有在里面写相应的代码啊,HEX文件小也是理所应当的
116910646|  楼主 | 2014-12-25 15:15 | 只看该作者
qq4988 发表于 2014-12-25 15:11
你这里面只是声明一个程序,并没有在里面写相应的代码啊,HEX文件小也是理所应当的 ...
也就是说 烧录到芯片中也无法运行是么
qq4988| | 2014-12-25 15:17 | 只看该作者
116910646 发表于 2014-12-25 15:15
也就是说 烧录到芯片中也无法运行是么
当然不能运行,还有你的设置有问题,我编译出来是8K多,你仔细看看IAR怎么用吧
116910646|  楼主 | 2014-12-25 15:26 | 只看该作者
qq4988 发表于 2014-12-25 15:17
当然不能运行,还有你的设置有问题,我编译出来是8K多,你仔细看看IAR怎么用吧 ...
好吧 ,反正这程序也不能烧录芯片
王七七| | 2014-12-25 18:14 | 只看该作者
wzda_gundam| | 2014-12-25 21:06 | 只看该作者
qupi();去屁 leiji();雷击...这函数名真是通俗易懂啊
hnkf118| | 2014-12-25 21:23 | 只看该作者
学习了。
tiger5z| | 2014-12-26 16:26 | 只看该作者
