编译BSP 一直出错,一直没有解决,运行./ltib 就出现下面错误,不知道怎么办了~~
580|0
空戈|  楼主 | 2015-4-10 00:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
你好,我在编译BSP时,运行 ./ltib 遇见了这样一个问题,没有搜索到解决方案,还望能指点~~~
./stdio.h:477:1: error: 'gets' undeclared here (not in a function)
_GL_WARN_ON_USE (gets, "gets is a security hole - use fgets instead");
make[3]: *** [clean-temp.o] Error 1
make[3]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/m4-1.4.16/lib'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/m4-1.4.16/lib'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/m4-1.4.16'
make: *** [all] Error 2
error: Bad exit status from /home/zyy/myzr/ltib/ltib/tmp/rpm-tmp.85654 (%build)
