[Allegro] 在orcad导入网表的时候,出现'C0603' for device 'C_C0603_1N' not fou...
5525|1
 楼主| li1376263028 发表于 2015-7-24 20:02 | 显示全部楼层 |阅读模式
出现的问题:
------ Directives ------
RIPUP_ETCH FALSE;
RIPUP_SYMBOLS ALWAYS;
Missing symbol has error FALSE;
SCHEMATIC_DIRECTORY 'D:/桌面文档保存位置/Cadence/1';
BOARD_DIRECTORY '';
OLD_BOARD_NAME 'D:/桌面文档保存位置/Cadence/2/sdsd.brd';
NEW_BOARD_NAME 'D:/桌面文档保存位置/Cadence/2/sdsd.brd';
CmdLine: netrev -$ -i D:/桌面文档保存位置/Cadence/1 -y 1 D:/桌面文档保存位置/Cadence/2/#Taaaaaa01236.tmp
------ Preparing to read pst files ------
Starting to read D:/桌面文档保存位置/Cadence/1/pstchip.dat
   Finished reading D:/桌面文档保存位置/Cadence/1/pstchip.dat (00:00:00.07)
Starting to read D:/桌面文档保存位置/Cadence/1/pstxprt.dat
   Finished reading D:/桌面文档保存位置/Cadence/1/pstxprt.dat (00:00:00.00)
Starting to read D:/桌面文档保存位置/Cadence/1/pstxnet.dat
   Finished reading D:/桌面文档保存位置/Cadence/1/pstxnet.dat (00:00:00.00)
------ Oversights/Warnings/Errors ------
#1   WARNING(SPMHNI-192): Device/Symbol check warning detected.
WARNING(SPMHNI-194): Symbol 'C0603' for device 'C_C0603_1N' not found in PSMPATH or must be "dbdoctor"ed.
#2   WARNING(SPMHNI-192): Device/Symbol check warning detected.
WARNING(SPMHNI-194): Symbol 'C0805' for device 'R_C0805_1K' not found in PSMPATH or must be "dbdoctor"ed.
------ Library Paths ------
MODULEPATH =  .
           C:/Cadence/SPB_16.3/share/local/pcb/modules
PSMPATH =  C:\Cadence\SPB_16.3\share\pcb\pcb_lib\symbols\
           C:\CADENCE\SPB_16.3\SHARE\PCB\PCB_LIB\
PADPATH =  C:\CADENCE\SPB_16.3\SHARE\PCB\pcb_lib\symbols\
------ Summary Statistics ------
netrev run on Jul 24 19:54:36 2015
   DESIGN NAME : 'PICE'
   PACKAGING ON Nov 17 2009 03:09:43
   COMPILE 'logic'
   CHECK_PIN_NAMES OFF
   CROSS_REFERENCE OFF
   FEEDBACK OFF
   INCREMENTAL OFF
   INTERFACE_TYPE PHYSICAL
   MAX_ERRORS 500
   MERGE_MINIMUM 5
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
   NET_NAME_LENGTH 24
   OVERSIGHTS ON
   REPLACE_CHECK OFF
   SINGLE_NODE_NETS ON
   SPLIT_MINIMUM 0
   SUPPRESS   20
   WARNINGS ON
No error detected
No oversight detected
  2 warnings detected
cpu time      0:00:39
elapsed time  0:00:00
按照网上百度的,路径我改了啊!修改环境变量那个,,,pcbenv文件我搜了整个安装目录都没有啊!!!
求大神帮帮忙啊,,,新人学Cadence,,,真难!
沉雨坠叶 发表于 2015-8-21 14:28 | 显示全部楼层
看看改改这两项试试
