[Allegro] 求各位大神解答
1318|0
 楼主| 段杭宇 发表于 2015-7-30 15:27 | 显示全部楼层 |阅读模式
我用cadence画完图之后想打包的时候出现这个错误,该怎么解决呢?
#1 ERROR(SPCODD-43): End of file encountered while reading PPT tables. The
END keyword might be missing from the part table file. Ensure that all the par~
t table files contain all keywords including END. Ensure that the END keyword ~
is followed by a period.
#2   ERROR(SPCODD-47): Packaging can not complete because the file F:/Concept~
Lib/zte_use/fcp2/part_table/part.ptf could not be loaded. There might be synta~
x errors in this file. Ensure that the syntax is correct before proceeding
