今天看到个自动导航扫地机,是用什么原理定位的?
5771|14
 楼主| ocon 发表于 2015-8-7 20:04 | 显示全部楼层 |阅读模式
 楼主| ocon 发表于 2015-8-7 20:08 | 显示全部楼层
或者根本没有定位功能,导航用半导体陀螺,所谓的“导航仪”只是向四周发射红外线,照出房间的范围。
mmuuss586 发表于 2015-8-8 12:26 | 显示全部楼层
估计是把房间的一些距离测试出来吧;
Sunny左瞳 发表于 2015-8-13 12:39 | 显示全部楼层
我还以为是视频,特地找了个耳机:'(:'(:'(。
罪过罪过~  发表于 2015-8-13 14:36
ghost2 发表于 2015-8-17 10:35 来自手机 | 显示全部楼层
northstar,原来的evolution robotics专利,现在ER已经并入irobot
是的,北极星,irobot的有款玩具机器人就搭载了,可以自动回航充电,在回航时会左右移动几次用于精确计算充电坞位置,充电乌做天花板上投影红.....  发表于 2016-11-6 15:01
lwb_2888 发表于 2015-9-9 11:20 | 显示全部楼层
找了半天,没有找到楼主视频
 楼主| ocon 发表于 2015-9-9 11:43 | 显示全部楼层
找了半天,没有找到楼主视频
我在TB上看到的,吹得很神奇。
没有伞的孩子 发表于 2015-9-16 14:37 | 显示全部楼层
LEADIY-M3C串口姿态模块 卡尔曼 陀螺仪、气压计、电子罗盘
通信接口:串口,默认波特率115200
模块支持波特率:9600、115200、230400、460800
数据更新:每2MS---2.5MS输出一次姿态角度
小板尺寸:16mm*26mm
引脚间距:2.54mm(100mil)
供电电源:3V--5V(板上集成LDO)
通过串口或IIC接口读数据
串口直接输出角度
帧率达400Hz,达到每2--2.5mS更新数据帧的超快更新率
LEADIY-M3C is the newest and greatest version of intchip smart uart output IMU module. M3C is 10Dof IMU module with auto run feature. The goal of the M3C is to simplify the development of projects based upon the most powerful and new consumer grade inertial, magnetic and pressure sensors. M3C incorporates three sensors: an MPU-6050(MEMS triple-axis gyro with triple-axis accelerometer ), HMC5883L(triple-axis magnetometer), thus it can give you nine degrees of inertial measurement. In addition, M3C incorporates BMP180(pressure sensor). There is also a cortex MCU on board, by reading the data from the various sensors, it is possible to compute precisely the orientation of M3C in the space. The orientation result is output through uart interface. The main application of M3C is orientation sensing such as drones, action game controller, self-balancing robot, industrial measuring instrument, autonomous vehicles and video stabilization systems. M3C is a tiny but powerful orientation solution.
The cascaded Kalman filter is used in our system to improve the estimated attitude.The precision of the attitude is up to 0.01 Deg. The output frame rate is up to 400Hz. The uart baud rate can be configured up to 460800.
And designed computer monitoring software to monitor the change of the attitude.Simply connect M3C to the serial TX and RX pins with a USB To TTL Serial Converter Adapter Module , open our VisualIMU terminal program, you can see the changing of the attitude, current temperature, air pressure, altitude, Gyroscope angular velocity, acceleration value, magnetism. The data outputted is varied with the position and angle of the module.
You can also read the sensors from the unified IIC access routines, before you do this, you should stop the on-board MCU’s access by sending stop serial output command.
We also provide some example software that demos the used of LEADIY-M3C. Demo code worked on STM32 board and demo code worked on arduino platform can be provided.
Figure 2 shows relative data output of M3C in horizontal state.The compass is used to indicate the heading of the module.
叶不羞 发表于 2016-10-31 17:42 | 显示全部楼层
通信接口:串口,默认波特率115200
模块支持波特 ...
你好,我看了你的关于自动导航仪的回复,有一点事情想打扰你一下,希望你能够提供一些帮助,万分感谢!是这样的,我是一名大学生,打算做一个关于扫地机器人的科创项目,但是由于大一专业课还没有学习,所以对于很多东西不是很了解,比如这个陀螺仪定位系统,你能给我提供一些包括但不仅限于陀螺仪定位系统的讲解或者建议或者一些相关参考资料来源吗?
开心马驹 发表于 2016-11-3 11:51 | 显示全部楼层
红外,陀螺仪,加上智能算法。扫地机器人主要问题就是算法了,别的问题不太大
zxlzqp 发表于 2016-11-7 20:53 来自手机 | 显示全部楼层
陀螺仪在扫地机器人中的作用是什么?
 楼主| ocon 发表于 2016-11-7 21:23 | 显示全部楼层
陀螺仪在扫地机器人中的作用是什么?
转弯的时候测转过的角度。
没有名字行吗 发表于 2016-12-6 15:51 | 显示全部楼层
我也以为是视频
