[信号传感和变送] valcom压力变送器
1133|0
 楼主| szdandb 发表于 2015-9-18 16:47 | 显示全部楼层 |阅读模式
【日本沃康VALCOM常用型号】
VPRQF-A3-4.9MPA-4
VPC-P-35.0MPA.1VAOM(H)-4
VSG3-A2-160PA-4-M5
VESW400G2/DEK
VSW2-31-4-(-100~500KPA)WR-H500KPG
VPRNP-A6-101.3Kpa(abs)TL-4
VLC-40KNG672
VMM7-4S-D-N-8
VESIM20ATI-E5-2M
VESZ200R2
VPRF-A3-1MPA-W-4
VSM3-2S-A3-A3-4
VPRQ-A3-2MPa-4
VPRNP-A6-45.08KPaTL-4
VHR3-A6-(-1.96~29.4KPa)TL-4
VPRQ-A6-3MPaTL-4
VPRQ-A6-1MPaTL-4-B43/NM
VLGM3-GV-RS-T-0
VPS-D-50.0MPaW-3SAO(HHH)-P-4
VPRT-50MPW
VPRH-D-210KW-2SA(HH)-2U
VPRQ-A5-21MPa-4
VPRF-A6-0.7MPaT-4-2M
VPRQ-A3-5MPaS-5
VPRQF-A4-100KW-4
VPRT-A5-10MPa-4
VHG3-A3-200KPA(abs)N-4-SMI
VHR3-A5-(-30~-80KPA)N-4
VPS-A4-50.0MPaW-NK-4
VTR-201-500N
VHR3-A5-200KPAW-4/FTC
VPRV-D-20.0MPa-2SA0(HL)-1 △(PH)-22U
VESY-100-R2-5
VPRTF-50.0MP-5M
VPRQ-A2-30MPa-5-5M
VSS-V32RC-NG
VESIM01-2M
VPRQ-A3-50KS-5
VPRT-A3-50MPa-4
VPRF-A3-30MPA-4
VPRQ-A3-20MPA-4
VPVT-A3-500KW-4
VPRF-A3-20MPA-4
VESIM20
C47N-0-ZF
VPRQ-A3-30MPaS-5
VPRQ-A3-(-0.1-1)MPAS-4
VPVT-A4-30MPAS-5
VPVT-A3-300KS-5
VLS-100K
VPRQ-A5-35MPA-4-3M(连接螺纹R3/8)
VPRF-200K
VGM2-2SO-A3-1-4
VSW2-02-4-5.00MPA-RR-VT005MPGR2
VGM-2SO-A5-1
VLS-5K
VLU2-100K
VSM3-2S-A3-A3-4
VPRQ-A2-30MPA-5
VPRVS-2S(HH)-30.0MPA-A2-22U
VHR3-A5-200KPAN-4/DF
VESY100R2(ANI-E5-5M)
VSG3-A2-1960PA-4-5M
VPRQ-A3-5MPaS-5
VPLQ-A3-350K-4C
VPRT-A5--0.1--1MPa-4-2M
VPRQ-A5--0.1--1MPa-4-2M
VPRT-A3-1MPA-4
VLS-10K
VLGM3-GV-RS-7-0
MQ-B-SR-2MPA-M-H-4
VHR3-A4-50kPaN-4
VMM6-2S-B4-GV-8
C37GV-SA3-DZFE
VESY100
SR3-A3-15KPA-4
VLC-500NE344;220V;500N;
VSM3-2S-A3-A2-4
MT-B-TR-30MPa-M(H)-4
VPRF-A6-20MPaS-4-5m
VPRF-A6-2MPaS-4-5m
VPRF-A6-5MPaS-4-10m
VPRQ-A6-1MPaT-4
VPRQ-A3-50K-5 DC12V 4-20MA 带显示器C37N-S 110v
VPJ-A5-PSL-(±980N)-4
VSW2-02-4-700KPAWN-H700KPGR2
VPRT-A4-35MPAS-4,CABLE20M(DC24V)
PS-VESIM05-5M
VSW2-02N-4-50.0MPAWR-VT050MPGR2
HSSC-D-AS-100-100-F2-P-PG8A
RBC-T-(-20kPa)-2VA(LH)-4-A5
VHR3-A5-(-20kPa)N-4
VHR3-A6-(-1.96-29.4KPa)TL-4
VGM-2SO-B4
VPW10AC--300KG
VPRQF-A3-20MPAS
RBC-T-(-30kPa)-2VA(LH)-4-A5
VHR3-A5-(-30kPa)N-4
VSR3-A6-(-1~2KPa)-4
VSR3-A6-(±1KPa)T-4
VSR3-A6-3KPaT-4
VSR3-A6-(-50Kpa)S-4
VSG3-A2-1960PA-4-M5
VPRN-A6-(±760mmHg)-4
VSR3-A6-(±760mmHg)-4
VMM6-2SO-D-N-8
VESVM10-5M-G3NF-R2M-S3
