我使用EPM1270,并口JTAG下载,加电下载时
4482|6
 楼主| wswh2o 发表于 2007-11-19 10:35 | 显示全部楼层 |阅读模式
总是<br />“Error:&nbsp;The&nbsp;instruction&nbsp;register&nbsp;length&nbsp;for&nbsp;the&nbsp;EPM1270T144&nbsp;device&nbsp;at&nbsp;position&nbsp;1&nbsp;in&nbsp;the&nbsp;JTAG&nbsp;chain&nbsp;is&nbsp;unknown”<br />断电下载时,开始正常,中间有时<br />“Error:&nbsp;Can't&nbsp;Verify&nbsp;device&nbsp;number&nbsp;1”<br />有时成功。<br />有知道原因的吗??<br /><br /><br />另,时钟信号怎么定义才不会告警<br />“&nbsp;&nbsp;&nbsp;&nbsp;Info:&nbsp;Assuming&nbsp;node&nbsp;&quot;clk&quot;&nbsp;is&nbsp;an&nbsp;undefined&nbsp;clock”<br /><br /><br />谢谢!
xjg1111 发表于 2007-11-19 11:41 | 显示全部楼层
re
JTAG应该是要加电下载的,你还是检查一下硬件,是否连接正常。下载线是否正确。<br /><br />再看看,能不能把芯片的型号检测出来。<br /><br />对于时钟的定义,有一个选项,勾上就不会提示了。<br />如果时钟不高,你完全可以不用管它。
 楼主| wswh2o 发表于 2007-11-19 11:15 | 显示全部楼层
meirenkanma
 楼主| wswh2o 发表于 2007-11-19 13:32 | 显示全部楼层
时钟不高的界限是多少??
断电下载时<br /><br />Info:&nbsp;Started&nbsp;Programmer&nbsp;operation&nbsp;at&nbsp;Mon&nbsp;Nov&nbsp;19&nbsp;13:27:28&nbsp;2007<br />Info:&nbsp;Device&nbsp;1&nbsp;contains&nbsp;JTAG&nbsp;ID&nbsp;code&nbsp;0x020A30DD<br />Info:&nbsp;Device&nbsp;1&nbsp;silicon&nbsp;ID&nbsp;is&nbsp;ALTERA04-1<br />Info:&nbsp;Erasing&nbsp;MAXII&nbsp;configuration&nbsp;device(s)<br />Info:&nbsp;Programming&nbsp;device(s)<br />Info:&nbsp;Performing&nbsp;verification&nbsp;of&nbsp;type&nbsp;Nominal&nbsp;on&nbsp;device(s)<br />Info:&nbsp;Successfully&nbsp;performed&nbsp;operation(s)<br />Info:&nbsp;Ended&nbsp;Programmer&nbsp;operation&nbsp;at&nbsp;Mon&nbsp;Nov&nbsp;19&nbsp;13:27:34&nbsp;2007<br /><br />此时,无法检测到JTAG&nbsp;chain<br /><br />加电下载时<br /><br />Info:&nbsp;Started&nbsp;Programmer&nbsp;operation&nbsp;at&nbsp;Mon&nbsp;Nov&nbsp;19&nbsp;13:31:41&nbsp;2007<br />Info:&nbsp;Device&nbsp;1&nbsp;contains&nbsp;JTAG&nbsp;ID&nbsp;code&nbsp;0x020A30DD<br />Error:&nbsp;Can't&nbsp;recognize&nbsp;silicon&nbsp;ID&nbsp;for&nbsp;device&nbsp;1<br />Error:&nbsp;Operation&nbsp;failed<br />Info:&nbsp;Ended&nbsp;Programmer&nbsp;operation&nbsp;at&nbsp;Mon&nbsp;Nov&nbsp;19&nbsp;13:31:41&nbsp;2007<br /><br />此时,检测硬件可以检测到EPM1270的芯片
 楼主| wswh2o 发表于 2007-11-19 13:34 | 显示全部楼层
silicon ID是什么意思??
 楼主| wswh2o 发表于 2007-11-19 14:33 | 显示全部楼层
可能找到原因了
我的下载线是<br />并口-》并口延长线-》下载板-》排线-》板子<br /><br />换了一根短的排线基本好了,试了5次没有问题。
jzt369 发表于 2007-11-19 17:15 | 显示全部楼层
恭喜你啊,其实问题的原因是多样的
