这个这些警报怎么处理第一次用quartus软件
3370|3
 楼主| jack.king 发表于 2009-8-11 17:04 | 显示全部楼层 |阅读模式
Warning: I/O standard setting for individual pin "ale" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "Hiaddr[0]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "Hiaddr[1]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "Hiaddr[2]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "Hiaddr[3]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "data[0]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "data[1]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "data[2]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "data[3]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "data[4]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "data[5]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "data[6]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "data[7]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "wr" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "outData[0]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "outData[1]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "outData[3]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "outData[5]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "outData[2]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
Warning: I/O standard setting for individual pin "outData[4]" not supported for selected device family -- setting I/O standard for pins according to device-wide I/O standard
 楼主| jack.king 发表于 2009-8-11 17:05 | 显示全部楼层
在google里面查到了些原因但是都没有觉得想请教各位大牛能不能帮我解决下
ce180303 发表于 2009-8-11 17:13 | 显示全部楼层
Settings-> Device-> Device and Pin-0ptions> Voltage-> Default I / O standard
 楼主| jack.king 发表于 2009-8-29 14:50 | 显示全部楼层
谢谢LS
