// INPUT DATA
// Crys_freq(Hz): 26000000 Crys_tol(ppm): 10 IF_mode: 2 High_perf_Ch_Fil: 1 OSRtune: 0 Ch_Fil_Bw_AFC: 0 ANT_DIV: 0 PM_pattern: 0
// MOD_type: 2 Rsymb(sps): 1000 Fdev(Hz): 40000 RXBW(Hz): 150000 Manchester: 0 AFC_en: 0 Rsymb_error: 0.0 Chip-Version: 2
// RF Freq.(MHz): 490 API_TC: 28 fhst: 300000 inputBW: 0 BERT: 0 RAW_dout: 0 D_source: 0 Hi_pfm_div: 1
// # RX IF frequency is -406250 Hz
// # WB filter 1 (BW = 99.20 kHz); NB-filter 1 (BW = 99.20 kHz)
以上是由WDS软件生成的,这些参数是否表示已在寄存器中设置?
