这些warning 是什么意思,全是一类
2745|0
 楼主| Tom2007 发表于 2009-9-22 11:31 | 显示全部楼层 |阅读模式
WARNING:Xst:2591 - "fre_q.vf" line 68: attribute on instance <IBUF_DELAY_VALUE> overrides generic/parameter on entity. It is possible that simulator will not take this attribute into account.
WARNING:Xst:2591 - "fre_q.vf" line 68: attribute on instance <IOSTANDARD> overrides generic/parameter on entity. It is possible that simulator will not take this attribute into account.
WARNING:Xst:2591 - "fre_q.vf" line 63: attribute on instance <DRIVE> overrides generic/parameter on entity. It is possible that simulator will not take this attribute into account.
WARNING:Xst:2591 - "fre_q.vf" line 63: attribute on instance <IOSTANDARD> overrides generic/parameter on entity. It is possible that simulator will not take this attribute into account.
WARNING:Xst:2591 - "fre_q.vf" line 63: attribute on instance <SLEW> overrides generic/parameter on entity. It is possible that simulator will not take this attribute into account.
