[Allegro] orcad导入allegro后看不到元件
1282|2
 楼主| dickeybird22 发表于 2017-7-18 10:11 | 显示全部楼层 |阅读模式
netrev run on Jul 18 9:58:17 2017
   DESIGN NAME : 'Y900_KEY'
   PACKAGING ON Apr 21 2011 10:02:30
   COMPILE 'logic'
   CHECK_PIN_NAMES OFF
   CROSS_REFERENCE OFF
   FEEDBACK OFF
   INCREMENTAL OFF
   INTERFACE_TYPE PHYSICAL
   MAX_ERRORS 500
   MERGE_MINIMUM 5
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
   NET_NAME_LENGTH 24
   OVERSIGHTS ON
   REPLACE_CHECK OFF
   SINGLE_NODE_NETS ON
   SPLIT_MINIMUM 0
   SUPPRESS   20
   WARNINGS ON
No error detected
No oversight detected
No warning detected
cpu time      0:01:11
elapsed time  0:00:00
看不到有错误,刚学,有高手指导一下吗
gaochy1126 发表于 2017-7-19 13:25 | 显示全部楼层
图层的问题吗?
是不是显示层都关掉了?
