[ARM程序分析与设计] 天祥开发板中断重映射问题
4451|2
 楼主| fangzhuang2004 发表于 2010-8-13 22:30 | 显示全部楼层 |阅读模式
void Isr_Init(void)
unsigned int cc;
pISR_UNDEF = (unsigned)HaltUndef;
pISR_SWI = (unsigned)HaltSwi;
pISR_PABORT = (unsigned)HaltPabort;
pISR_DABORT = (unsigned)HaltDabort;
//中断向量重映射
for (cc = _RAM_STARTADDRESS;cc < (_RAM_STARTADDRESS + 0x20);cc += 4)
  *((volatile unsigned *)cc) = 0xEA000000 + ((unsigned int)Image$$RO$$Base - 0x0c000000 - 8) / 4;
//rINTCON=0x1;      // Vectored Int. IRQ enable,FIQ disable
rINTCON = 0x5;      // Non-vectored,IRQ enable,FIQ disable
rINTMOD = 0x0;      // All=IRQ mode
rINTMSK |= BIT_GLOBAL | BIT_EINT4567;   // All interrupt is masked.
??*((volatile unsigned *)cc) = 0xEA000000 + ((unsigned int)Image$$RO$$Base - 0x0c000000 - 8) / 4??????
什么意思?
一级菜鸟 发表于 2010-8-13 22:35 | 显示全部楼层
将cc做为一个RAM地址来引用,后面是需要放入该地址的计算值
as4252 发表于 2010-8-22 12:23 | 显示全部楼层
