- #include "stm32f10x.h"
- #include "led.h"
- #include "usart.h"
- #include "adc.h"
- uint8_t curr_state=0;
- uint8_t counter=0;
- uint8_t head;
- uint8_t dataADC[25];
- extern __IO uint16_t ADC_ConvertedValue;
- void Delay(__IO u32 nCount);
- int main(void)
- /* USART1 config 115200 8-N-1 */
- USART1_Config();
- ADC1_Init();
- while(1)
- switch(curr_state){
- case 0:
- head = 0x2A;
- dataADC[counter]=0x2A;
- counter++;
- GPIO_WriteBit(GPIOB, GPIO_Pin_0, Bit_RESET);
- GPIO_WriteBit(GPIOA, GPIO_Pin_5, Bit_RESET);
- GPIO_WriteBit(GPIOA, GPIO_Pin_4, Bit_RESET);
- GPIO_WriteBit(GPIOA, GPIO_Pin_3, Bit_RESET);
- Delay(2000);
- dataADC[counter]= ADC_ConvertedValue;
- //dataADC[counter]=(uint8_t)(ADC_ConvertedValue & 0xFF);
- dataADC[counter+1]=(uint8_t)((ADC_ConvertedValue >>8 )& 0xFF);
- counter+=2;//2
- Delay(20);
- curr_state=1;
- break;
- case 1:
- GPIO_WriteBit(GPIOA, GPIO_Pin_5, Bit_SET);
- Delay(2000);
- dataADC[counter]=(uint8_t)(ADC_ConvertedValue & 0xFF);
- counter+=2;//4
- Delay(20);
- curr_state=2;
- case 2:
- GPIO_WriteBit(GPIOA, GPIO_Pin_3, Bit_SET);
- Delay(2000);
- counter+=2;//6
- Delay(20);
- curr_state=3;
- case 3:
- GPIO_WriteBit(GPIOA, GPIO_Pin_4, Bit_SET);
- Delay(2000);
- counter+=2;//8
- Delay(20);
- curr_state=4;
- case 4:
- Delay(2000);
- counter+=2;//10
- Delay(20);
- curr_state=5;
- case 5:
- counter=0;
- dataADC[1] = ADC_GetConversionValue(ADC1);
- //dataADC[2] = Get_Adc(1);
- UART1_Send_Array(dataADC,11);
- Delay(2000);
- // printf("\r\n The current AD value = 0x%04X \r\n", ADC_ConvertedValue[0]);
- curr_state=0;
- break;
- default:
- break;
- void Delay(__IO uint32_t nCount)
- for(; nCount != 0; nCount--);
ADC配置程序如下:
- #include "adc.h"
- #define ADC1_DR_Address ((u32)0x40012400+0x4c)
- __IO uint16_t ADC_ConvertedValue;
- */ **ADC1 GPIO Configuration
- PA2 ------> ADC1_IN2
- PB1 ------> ADC1_IN9
- static void ADC1_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Enable DMA clock */
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
- /* Enable ADC1 and GPIOA and GPIOB clock */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC, ENABLE);
- /*Configure GPIO pins : PC14 PC15 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14|GPIO_Pin_15;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- /* Configure PA.03|4|5 as analog output */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- /* Configure PB.00 as analog output */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- /* Configure PA.02 as analog input */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
- /* Configure PB.01 as analog input */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
- static void ADC1_Mode_Config(void)
- DMA_InitTypeDef DMA_InitStructure;
- ADC_InitTypeDef ADC_InitStructure;
- /* DMA channel1 configuration */
- DMA_DeInit(DMA1_Channel1);
- DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
- DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_ConvertedValue;
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
- DMA_InitStructure.DMA_BufferSize = Numberofchannel;
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
- DMA_InitStructure.DMA_Mode = DMA_Mode_Normal ;
- DMA_InitStructure.DMA_Priority = DMA_Priority_Low;
- DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
- DMA_Init(DMA1_Channel1, &DMA_InitStructure);
- /* Enable DMA channel1 */
- DMA_Cmd(DMA1_Channel1, ENABLE);
- /* ADC1 configuration */
- ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
- ADC_InitStructure.ADC_ScanConvMode = ENABLE ;
- ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
- ADC_InitStructure.ADC_NbrOfChannel = Numberofchannel;
- ADC_Init(ADC1, &ADC_InitStructure);
- RCC_ADCCLKConfig(RCC_PCLK2_Div6);
- ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 1, ADC_SampleTime_1Cycles5);
- ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 2, ADC_SampleTime_1Cycles5);
- /* Enable ADC1 DMA */
- ADC_DMACmd(ADC1, ENABLE);
- /* Enable ADC1 */
- ADC_Cmd(ADC1, ENABLE);
- ADC_ResetCalibration(ADC1);
- while(ADC_GetResetCalibrationStatus(ADC1));
- /* ADCУ׼ */
- ADC_StartCalibration(ADC1);
- /* µÈ´ýУ׼Íê³É*/
- while(ADC_GetCalibrationStatus(ADC1));
- /* ÓÉÓÚûÓвÉÓÃÍⲿ´¥·¢£¬ËùÒÔʹÓÃÈí¼þ´¥·¢ADCת»» */
- ADC_SoftwareStartConvCmd(ADC1, ENABLE);
- void ADC1_Init(void)
- ADC1_GPIO_Config();
- ADC1_Mode_Config();
