[通用8051核FLASH系列] HC89F003温度采集显示分享
3848|33
 楼主| 工工 发表于 2017-12-5 09:45 | 显示全部楼层 |阅读模式
收到芯圣的仿真器,玩了一个星期,比较容易上手。下面是我自己写的一个温度检测程序,用LED显示的,完全可应用到产品上。借鉴官方例子里的看门狗,ADC,LED应用。现在正在研究驱动LCD液晶显示,过几天,写完程序,再跟大家分享。
#include "HC89F003.h"
#define     u8       unsigned char
#define     u16      unsigned int
#define     u32      unsigned long
/***********************RAM太小,常量请放ROM中,加code.*放内部RAM加data*放外部RAM加xdata*不加默认放xdata********************/
  /***********************LED段码表***P2.1-A,P2.2-E,P2.3-D,P2.4-C,P2.5-G,P2.6-DP,P0.6-F,P0.7-B,P2.0-S2,P0.5-S3,P0.3-S1********/
u8 code ledDuan[16] = {0x20,0x6E,0x50,0x44,0x0E,0x84,0x80,0x6C,0x00,0x04,//0-9
                       0xFE,0xB0,0x90,0x98, 0xDA,0xB2};         //NULL,C,E,F,r,L
  /***********************温度表,扩大10倍**********************************************************/
  u16 code ntcPositive[250] =
{ 77,  82,  86,  91,  95, 101, 106, 111, 117, 123,          //1~10
130, 136, 143, 151, 158, 166, 174, 183, 192, 201,        //11~20
211, 221, 232, 243, 255, 267, 279, 292, 305, 319,        //21~30
334, 349, 365, 381, 398, 415, 433, 452, 471, 491,        //31~40
512, 534, 556, 579, 602, 627, 652, 678, 705, 733,        //41~50
761, 791, 821, 853, 885, 918, 952, 987, 1023,1059,        //51~60
1097,1136,1176,1217,1258,1301,1345,1390,1436,1483,        //61~70
1530,1579,1629,1680,1732,1785,1839,1894,1950,2007,        //71~80
2064,2123,2183,2243,2305,2367,2431,2495,2559,2625,        //81~90
2692,2759,2827,2895,2964,3034,3105,3176,3247,3319,        //91~100
3392,3465,3538,3612,3686,3761,3835,3910,3985,4061,        //101~110
4136,4211,4287,4363,4438,4514,4589,4664,4740,4815,        //111~120
4889,4964,5038,5112,5186,5259,5332,5404,5476,5548,        //121~130
5619,5689,5759,5829,5898,5966,6034,6101,6167,6233,        //131~140
6298,6363,6426,6489,6552,6613,6674,6734,6793,6852,        //141~150
6910,6967,7023,7079,7134,7188,7241,7293,7345,7396,        //151~160
7446,7496,7544,7592,7639,7686,7731,7776,7820,7864,        //161~170
7906,7948,7990,8030,8070,8109,8148,8186,8223,8259,        //171~180
8295,8330,8365,8399,8432,8465,8497,8529,8560,8590,        //181~190
8620,8649,8678,8706,8734,8761,8787,8814,8839,8864,        //191~200
8889,8913,8937,8960,8983,9005,9027,9049,9070,9091,        //201~210
9111,9131,9151,9170,9189,9207,9225,9243,9260,9277,        //211~220
9294,9310,9327,9342,9358,9373,9388,9402,9417,9431,        //221~230
9445,9458,9471,9484,9497,9510,9522,9534,9546,9557,        //231~240
9569,9580,9591,9601,9612,9622,9632,9642,9652,9662,          //241-250
/*********对应段里的位置************************************************************************/
#define NUL 10
#define C   11
#define E   12
#define F   13
#define r   14
#define L   15
sbit PTC=P1^0 ;
bit bCf=0;
bit bPowerOn=0;
u8 errNtc=0;
u8 realTemp=1;
/*********端口设置************************************************************************/
void GPIOSysInit(void)
        P0M1 = 0x88;
        P0M2 = 0x88;
        P0M3 = 0x88;
        P2M0 = 0x88;
        P2M1 = 0x88;
        P2M2 = 0x88;
        P2M3 = 0x88;
/**************看门狗设置*******************************************************************/
void IWDG_Init(void)
/***********************************WDT配置初始化**************************************/
        WDTC = 0x57;                //允许WDT复位,允许掉电/空闲模式下运行,1024分频
        //WDT使用的是RC44K时钟,WDT_CLOCK_1024是1024分频,初值为0xFF
        //定时时间         = 1024 * 0xFF / 44000
        //                        = 5.93s
        WDTCCR = 0xFF;                //写入00时,将关闭WDT功能(但不关闭内部低频RC),
                                //即相当于禁止WDT。写入非0数据时,将启动WDT。
/*****************喂狗***********************************************************/
void CLRWDT(void)
  WDTC |= 0x10;                   //喂狗
/************ADC设置*********************************************************************/
void ADC_Init(void)
{  /************************************ADC初始化*****************************************/
        P0M0 = P0M0|0x03;                                          //P00设置为模拟输入
        ADCC0 = 0x80;                                        //打开ADC转换电源
        ADCC1 = 0x00;                                        //选择外部通道0
        ADCC2 = 0xCD;                                        //转换结果10位数据,数据右对齐,ADC时钟16分频  ,1MHz
        ADCC0 |= 0x40;                                        //启动ADC转换
/*****************延时***********************************************************/
void Delayus(u8 us)
    u8 i,j;
      for(i=0; i<us; i++)
        for(j=0; j<10; j++);
/*****************数码管显示***********************************************************/
void LedDisplay(u8 *dat)
    u8 buff[4],i;
    CLRWDT();
        for(i=0; i<4; i++)
             buff = *dat++;
            P0_3=1;
            P2_0=0;
                   P0_5=0;
            P2= (P2&0XC1)|((ledDuan[buff[0]])&0x3E);
            P0= (P0&0X3F)|((ledDuan[buff[0]])&0xC0);
            Delayus(200);
            P2= 0XFE;
            P0= 0XC0;
              P0_3=0;
             P2_0=1;
              P0_5=0;
            if(buff[3] == F)
                P2_6= 0;
            else
                P2_6= 1;
            P2= (P2&0XC1)|((ledDuan[buff[1]])&0x3E);
            P0= (P0&0X3F)|((ledDuan[buff[1]])&0xC0);
               Delayus(200);
            P2= 0XFE;
            P0= 0XC0;
              P0_3=0;
            P2_0=0;
            P0_5=1;
            if(buff[3] == C)
                P2_6= 0;
                 else
                P2_6= 1;
            P2= (P2&0XC1)|((ledDuan[buff[2]])&0x3E);
            P0= (P0&0X3F)|((ledDuan[buff[2]])&0xC0);
                Delayus(200);
            P2= 0XFE;
            P0= 0XC0;
/***************温度显示*************************************************************/
void DisplayTmp(u16 dat)
              u8 tmp[4];
              CLRWDT();
              tmp[0] = dat/100;
              tmp[1] = dat/10%10;
           // tmp[1]=tmp[1]%10;
              tmp[2] = dat%10;
              if(dat < 100)
                tmp[0] = NUL;
                    if(dat<10)
                  tmp[1] = NUL;
              if(bCf)
               tmp[3] = F;
              else
               tmp[3] = C;
              LedDisplay(tmp);
/***************检测温度******************************************************************/
void AdcSampling(void)
    u8 i=0;
    static u8 j=0,p=0;
    static u16 sum=0,k=0;
       CLRWDT();
       if(ADCC0&0x20)//ADC转换中断
             ADCC0 &=~ 0x20;                                        //清除标志位
           if(j > 49)   //50次
             sum=sum/5;
             j = 0;
             if(sum >10000)        // < 0 故障
                k=0;
                  //if(!bPowerOn)//开机时
                        p++;
                        if(p > 20)                                //2s
                           p = 0;
                           errNtc = 1;//NTC 短路
                  //else
                      // k=0;
                      // p=0;
                      // j=0;
                else if(sum <20)
                p=0;
                        k++;
                        if(k > 1050)                                //30s
                           k = 0;
                           errNtc = 2;//NTC 开路
                  //else
                      // k=0;
                      // j=0;
                else//无故障
                     if(sum<77)
                         realTemp = 0;
                       if(sum>9557)
                         realTemp =240;
                   for(i=0; i<241; i++)//查询温度
                     if(sum < (ntcPositive))
                           realTemp = i;
                           if(realTemp >= 240)//温度超限
                                    realTemp = 240;
                               break;
                   errNtc = 0;//故障解除
                   k = 0;
                        p=0;
                  sum=0;
              else
                  j++;
                    sum+=  ADCR;                        //获取ADC的值
/*************初始化********************************************************************/
void SystemInit(void)
/************************************系统初始化****************************************/
        WDTCCR = 0x00;                                                //关闭看门狗
        while((CLKCON&0x20)!=0x20);                        //等待内部高频晶振起振
        CLKSWR = 0x51;                                                //选择内部高频时钟为主时钟,内部高频RC2分频,Fosc=16MHz
        while((CLKSWR&0xC0)!=0x40);                        //等待内部高频切换完成
        CLKDIV = 0x01;                                                //Fosc1分频得到Fcpu,Fcpu=16MHz
        GPIOSysInit(); //端口初始化
           ADC_Init();
           //Tim1_Init();
           IWDG_Init();
void main()
   u8 tmp[4];
    //u16 data dat;
         SystemInit();   //系统初始化
        while(1)
           CLRWDT();
             AdcSampling();//检测温度
           if(errNtc!=0)//故障时
               tmp[0] = E;
             tmp[1] = r;
               tmp[2] = r;
             tmp[3] = NUL;
               LedDisplay(tmp);//Err
           else
            DisplayTmp(realTemp);
效果图
效果图
冷画 发表于 2017-12-5 13:44 | 显示全部楼层
感谢分享
lisingch 发表于 2017-12-5 17:05 | 显示全部楼层
没用开发板,直接用了个转接板?
haibao1213 发表于 2017-12-6 13:49 | 显示全部楼层
路过,有机会可以合作一下。
sopc12 发表于 2017-12-6 14:36 | 显示全部楼层
不错不错
emco 发表于 2018-2-18 20:15 | 显示全部楼层
收藏,谢谢分享。
WENHX 发表于 2018-2-19 10:45 | 显示全部楼层
试试,谢谢了
xiaoqizi 发表于 2018-7-16 10:11 | 显示全部楼层
温度传感器用的那种啊
海力小卢as 发表于 2020-4-20 16:02 | 显示全部楼层
收藏,非常不错
uiint 发表于 2020-5-2 08:33 | 显示全部楼层
hellosdc 发表于 2020-5-2 08:33 | 显示全部楼层
芯圣的仿真器?
mituzu 发表于 2020-5-2 08:34 | 显示全部楼层
现在好多都是板载的
suzhanhua 发表于 2020-5-2 08:34 | 显示全部楼层
没有工程文件吗
没有工程文件吗
xietingfeng 发表于 2020-5-2 08:34 | 显示全部楼层
代码看着有点乱呢
isseed 发表于 2020-5-2 08:35 | 显示全部楼层
谢谢楼主的。
wangdezhi 发表于 2020-5-2 08:35 | 显示全部楼层
还有下文吗
biechedan 发表于 2020-5-2 08:35 | 显示全部楼层
看门狗,ADC,LED应用
chenci2013 发表于 2020-5-2 08:36 | 显示全部楼层
学习学习。
