安装inspectrum: git clone https://github.com/miek/inspectrum.gitsudo apt-get install qt5-default libfftw3-dev cmake pkg-configcd inspectrummkdir buildcd buildcmake ..makesudo make install若cmake时出错: -- The CXX compiler identification is GNU 5.4.0-- Check for working CXX compiler: /usr/bin/c++-- Check for working CXX compiler: /usr/bin/c++ -- works-- Detecting CXX compiler ABI info-- Detecting CXX compiler ABI info - done-- Detecting CXX compile features-- Detecting CXX compile features - done-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1") -- Checking for module 'fftw3f'-- Found fftw3f, version 3.3.4-- Could NOT find LIQUID (missing: LIQUID_LIBRARIES LIQUID_INCLUDES) CMake Error: The following variables are used in this project, but they are set to NOTFOUND.Please set them or make sure they are set and tested correctly in the CMake files:LIQUID_INCLUDES used as include directory in directory /home/ph/prefix/inspectrum used as include directory in directory /home/ph/prefix/inspectrum used as include directory in directory /home/ph/prefix/inspectrum used as include directory in directory /home/ph/prefix/inspectrum used as include directory in directory /home/ph/prefix/inspectrum used as include directory in directory /home/ph/prefix/inspectrum used as include directory in directory /home/ph/prefix/inspectrum used as include directory in directory /home/ph/prefix/inspectrum used as include directory in directory /home/ph/prefix/inspectrumLIQUID_LIBRARIES linked by target "inspectrum" in directory /home/ph/prefix/inspectrum-- Configuring incomplete, errors occurred!See also "/home/ph/prefix/inspectrum/build/CMakeFiles/CMakeOutput.log".解决方法:需要先编译安装liquid-dsp git clone git://github.com/jgaeddert/liquid-dsp.gitcd liquid-dsp./bootstrap.sh./configuremakesudo make install
