[技术问答] HC32L136J串口用库函数进不了接收中断
 楼主| sniper156 发表于 2019-12-23 15:44 | 显示全部楼层 |阅读模式
void TxIntCallback(void)
//    u8TxCnt++;
//    if(u8TxCnt<=1)
//        M0P_UART1->SBUF = u8TxData[1];
void RxIntCallback(void)
    uint8_t Res;
     //Uart_ClrStatus(UARTCH0,UartRC);
     //Res = Uart_ReceiveData(UARTCH0);   //鎺ユ敹鏁版嵁瀛楄妭
        //MC30UART_RX_Buffer[MC30_Rx_Index++]=Res;
   // Uart_DisableIrq(UARTCH0,UartRxIrq);
    // Uart_SendData(UARTCH0, Res);
    // Uart_EnableIrq(UARTCH0,UartRxIrq);
void ErrIntCallback(void)
void PErrIntCallBack(void)
void CtsIntCallBack(void)
void Bsp_Uart_Init(M0P_UART_TypeDef* UARTx , uint32_t bound)
    App_PortInit(UARTx);
    App_UartCfg(UARTx , bound);
//涓插彛寮曡剼閰嶇疆
void App_PortInit(M0P_UART_TypeDef* UARTx)
    stc_gpio_config_t stcGpioCfg;
    DDL_ZERO_STRUCT(stcGpioCfg);
    Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE); //浣胯兘GPIO妯″潡鏃堕挓
    if(UARTx == M0P_UART1)
        ///<TX
        stcGpioCfg.enDir = GpioDirOut;
        Gpio_Init(GpioPortA, GpioPin2, &stcGpioCfg);
        Gpio_SetAfMode(GpioPortA, GpioPin2, GpioAf1);          //閰嶇疆PA02 绔?彛涓篣RART1_TX
        ///<RX
        stcGpioCfg.enDir = GpioDirIn;
        Gpio_Init(GpioPortA, GpioPin3, &stcGpioCfg);
        Gpio_SetAfMode(GpioPortA, GpioPin3, GpioAf1);          //閰嶇疆PA03 绔?彛涓篣RART1_RX
    if(UARTx == M0P_UART0)
        ///<TX
        Gpio_Init(GpioPortA, GpioPin9, &stcGpioCfg);
        Gpio_SetAfMode(GpioPortA, GpioPin9, GpioAf1);          //閰嶇疆PA02 绔?彛涓篣RART1_TX
        ///<RX
        Gpio_Init(GpioPortA, GpioPin10, &stcGpioCfg);
        Gpio_SetAfMode(GpioPortA, GpioPin10, GpioAf1);          //閰嶇疆PA03 绔?彛涓篣RART1_RX
//涓插彛閰嶇疆
void App_UartCfg(M0P_UART_TypeDef* UARTx , uint32_t bound)
    uint16_t u16Scnt = 0;
    stc_uart_config_t  stcConfig;
    stc_uart_irq_cb_t stcUartIrqCb;
    stc_uart_multimode_t stcMulti;
    stc_uart_baud_t stcBaud;
    en_uart_mmdorck_t enTb8;
    DDL_ZERO_STRUCT(stcConfig);
    DDL_ZERO_STRUCT(stcUartIrqCb);
    DDL_ZERO_STRUCT(stcMulti);
    stcUartIrqCb.pfnRxIrqCb   = RxIntCallback;//中断入口地址
    stcUartIrqCb.pfnTxIrqCb   = TxIntCallback;
    stcUartIrqCb.pfnRxFEIrqCb = ErrIntCallback;
    stcUartIrqCb.pfnPEIrqCb   = PErrIntCallBack;
    stcUartIrqCb.pfnCtsIrqCb  = CtsIntCallBack;
    stcConfig.pstcIrqCb = &stcUartIrqCb;
    stcConfig.bTouchNvic = TRUE;
        if(TRUE == stcConfig.bTouchNvic)
                EnableNvic(UART0_IRQn,IrqLevel3,TRUE);
    stcConfig.enRunMode = UartMode3;//模式3
    stcConfig.enStopBit = Uart1bit;//1位停止位
    stcMulti.enMulti_mode = UartNormal;//正常工作模式
    Uart_SetClkDiv(UARTCH0,Uart8Or16Div);//采样分频
    Uart_SetClkDiv(UARTCH1,Uart8Or16Div);//采样分频
    stcBaud.u32Pclk = Sysctrl_GetPClkFreq();
    stcBaud.enRunMode = UartMode3;
    stcBaud.u32Baud = 9600;
        Sysctrl_SetPeripheralGate(SysctrlPeripheralUart0,TRUE);
        Uart_SetMultiMode(UARTCH0,&stcMulti);//多主机单独配置
        Uart_SetMMDOrCk(UARTCH0,UartDataOrAddr);
        Uart_Init(UARTCH0, &stcConfig);//串口初始化函数
        u16Scnt = Uart_CalScnt(UARTCH0,&stcBaud);//波特率值计算
        Uart_SetBaud(UARTCH0,u16Scnt);//波特率设置
        Uart_ClrStatus(UARTCH0,UartRC);//清接收请求
        Uart_ClrStatus(UARTCH0,UartTC);//清接收请求
        //Uart_EnableIrq(UARTCH0,UartRxIrq);//
        Uart_EnableFunc(UARTCH0,UartRx);//使能收发
        Uart_EnableFunc(UARTCH0,UartTx);//使能收发
        Sysctrl_SetPeripheralGate(SysctrlPeripheralUart1,TRUE);
        Uart_SetMultiMode(UARTCH1,&stcMulti);//多主机单独配置
        Uart_SetMMDOrCk(UARTCH1,UartDataOrAddr);
        Uart_Init(UARTCH1, &stcConfig);//串口初始化函数
        u16Scnt = Uart_CalScnt(UARTCH1,&stcBaud);//波特率值计算
        Uart_SetBaud(UARTCH1,u16Scnt);//波特率设置
        Uart_ClrStatus(UARTCH1,UartRC);//清接收请求
        Uart_EnableIrq(UARTCH1,UartRxIrq);//
        Uart_EnableFunc(UARTCH1,UartRx);//使能收发
void UART_Send_Char(M0P_UART_TypeDef*  uartx,uint8_t data)
       if(uartx == M0P_UART0)
            Uart_SendData(UARTCH0, data );
        else
            Uart_SendData(UARTCH1, data );
    //Uart_SendDataIt(uartx, data);
查询方式可接收数据
快速回复 返回顶部 返回列表
