- **函数信息 :I2CTXEmptyCheck(I2C_TypeDef *I2Cx)
- **功能描述 :检查发送中断标志位
- **输入参数 :I2C_TypeDef *I2Cx,选择I2C1,I2C2
- **输出参数 :无
- void I2CTXEmptyCheck(I2C_TypeDef *I2Cx)
- while(1)
- if(I2C_GetFlagStatus(I2Cx, I2C_FLAG_TX_EMPTY))
- break;
- **功能描述 :检查接收中断标志位
- **输出参数 :无
- void I2CRXFullCheck(I2C_TypeDef *I2Cx)
- while(1)
- if(I2C_GetFlagStatus(I2Cx, I2C_FLAG_RX_FULL))
- break;
- **函数信息 :I2CTXByte(I2C_TypeDef *I2Cx,unsigned short cmd,unsigned char temp)
- **功能描述 :I2C发送数据
- **输入参数 :I2C_TypeDef *I2Cx,选择I2C1,I2C2;cmd;temp
- **输出参数 :无
- void I2CTXByte(I2C_TypeDef *I2Cx,unsigned short cmd,unsigned char temp)
- I2C_SendData(I2Cx, temp);
- I2CTXEmptyCheck(I2Cx);
- **函数信息 :I2CRXByte(I2C_TypeDef *I2Cx)
- **功能描述 :I2C接收数据
- **输出参数 :temp
- unsigned char I2CRXByte(I2C_TypeDef *I2Cx)
- unsigned short temp;
- I2CRXFullCheck(I2Cx);
- temp = I2C_ReceiveData(I2Cx);
- return (unsigned char)temp;
- void I2C_WriteByte(unsigned char dev_addr, unsigned int addr,unsigned char Byte)
- I2C_PageWrite(dev_addr,addr,&Byte,1);
- unsigned char I2C_ReadByte(unsigned char dev_addr, unsigned int addr)
- unsigned char Byte;
- I2C_PageRead(dev_addr,addr,&Byte,1);
- return Byte;
- uint32_t I2C_PageWrite(unsigned char dev_addr,unsigned int addr,unsigned char *str,unsigned int num)
- unsigned short i;
- unsigned char *p;
- p = str;
- I2C_Cmd(I2C1, DISABLE);
- I2C_Send7bitAddress(I2C1, dev_addr<<1, I2C_Direction_Transmitter);
- I2C_Cmd(I2C1, ENABLE);
- temp = ((addr) & 0xff);
- I2CTXByte(I2C1,CMD_WRITE,temp); //tx memory addr
- for(i=0;i<num;i++)
- temp = *p;
- p++;
- if(i==(num-1))
- I2C1->IC_DATA_CMD =temp| 0x200; // //muaul set stop flag
- else
- I2CTXByte(I2C1,CMD_WRITE,temp); //tx data
- return 0;
- uint32_t I2C_PageRead(unsigned char dev_addr,unsigned int addr,unsigned char *str,unsigned int num)
- unsigned char temp=0;
- unsigned short i;
- I2C_Send7bitAddress(I2C1, dev_addr<<1, I2C_Direction_Receiver);
- str[i] = I2CRXByte(I2C1);
- I2C1->IC_DATA_CMD = 0x200; // //set stop flag
- return 0;
下面是串口数据输出:
