CAN接收筛选器配置问题
583|0
 楼主| 张さん 发表于 2020-4-25 13:30 | 显示全部楼层 |阅读模式
如下是配置为只接收扩展帧0x1314的筛选器配置,请问我想配置为只接收标准帧某个ID的话,应该怎么修改呢???
static void CAN_Filter_Config(void)
        CAN_FilterInitTypeDef  CAN_FilterInitStructure;
        CAN_FilterInitStructure.CAN_FilterNumber=0;
        CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
        CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
        CAN_FilterInitStructure.CAN_FilterIdHigh= ((((u32)0x1314<<3)|CAN_ID_EXT|CAN_RTR_DATA)&0xFFFF0000)>>16;
        CAN_FilterInitStructure.CAN_FilterIdLow= (((u32)0x1314<<3)|CAN_ID_EXT|CAN_RTR_DATA)&0xFFFF;
        CAN_FilterInitStructure.CAN_FilterMaskIdHigh= 0xFFFF;
        CAN_FilterInitStructure.CAN_FilterMaskIdLow= 0xFFFF;
        CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_Filter_FIFO0 ;
        CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
        CAN_FilterInit(&CAN_FilterInitStructure);
        CAN_ITConfig(CANx, CAN_IT_FMP0, ENABLE);
