STM32F103的I2C问题
706|0
 楼主| 一亚麻怡 发表于 2020-4-26 09:08 | 显示全部楼层 |阅读模式
uint8_t I2C_ByteWrite(uint8_t WriteDatas,uint8_t WriteAddr){
  I2C_GenerateSTART(EEPROM_I2Cx, ENABLE);
  I2CTimeout = I2CT_FLAG_TIMEOUT;
  /* Test on EV5 and clear it */
  while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_MODE_SELECT))
    if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(0);
  /* Send EEPROM address for write */
  I2C_Send7bitAddress(EEPROM_I2Cx, EEPROM_ADDRESS, I2C_Direction_Transmitter);
  /* Test on EV6 and clear it */
  while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED))
    if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(1);
  /* Send the EEPROM's internal address to write to */
  I2C_SendData(EEPROM_I2Cx, WriteAddr);
  /* Test on EV8 and clear it */
  while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
    if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(2);
  /* Send the byte to be written */
  I2C_SendData(EEPROM_I2Cx,WriteAddr);
    if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(3);
  /* Send STOP condition */
  I2C_GenerateSTOP(EEPROM_I2Cx, ENABLE);
        return 1;
uint8_t Current_Address_Read(uint8_t ReadDatas,uint8_t ReadAddr)
    if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(4);
  I2C_Send7bitAddress(EEPROM_I2Cx, EEPROM_ADDRESS, I2C_Direction_Receiver);
  while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED))               ||程序停在这里
    if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(5);
        while(I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_BYTE_RECEIVED)==0)
                        if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(6);
  ReadDatas=I2C_ReceiveData(EEPROM_I2Cx);
        /* Disable Acknowledgement */
  I2C_AcknowledgeConfig(EEPROM_I2Cx, DISABLE);
  /* Send STOP Condition */
                return 1;
int main(void)
        uint8_t read;
  USART_Config();
        LED_GPIO_Config();
        I2C_EE_Init();
  I2C_ByteWrite(10,EEP_Firstpage);
        Current_Address_Read(read,EEP_Firstpage);
        if(read==10)
          LED_G(on);
        }else
          LED_R(on);
  while (1)
   程序总是停在读EEPROM的过程传递I2C设备地址,不能继续往下执行,求解,把例程也看几遍,也想不出问题在哪。
