pwm问题
426|0
 楼主| 小小的人呀 发表于 2019-11-1 17:00 | 显示全部楼层 |阅读模式
大神们,请教你们一个问题 为什么我设置的TIM2的pwm总是输出的是高电平
代码如下:void MX_TIM2_Init(void)
  TIM_ClockConfigTypeDef sClockSourceConfig;
  TIM_MasterConfigTypeDef sMasterConfig;
  TIM_OC_InitTypeDef sConfigOC;
  htim2.Instance = TIM2;
  htim2.Init.Prescaler =71;
  htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim2.Init.Period = 9999;
  htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
     Error_Handler();
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
  if (HAL_TIM_PWM_Init(&htim2) != HAL_OK)
    Error_Handler();
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
    Error_Handler();
  sConfigOC.OCMode = TIM_OCMODE_PWM1;
  sConfigOC.Pulse = 4999;//设置占空比
  sConfigOC.OCPolarity = TIM_OCPOLARITY_LOW;
  sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
  if (HAL_TIM_PWM_ConfigChannel(&htim2, &sConfigOC, TIM_CHANNEL_4) != HAL_OK)
    Error_Handler();
   HAL_TIM_MspPostInit(&htim2);
/*这是pwm输出口的配置*/
if(timHandle->Instance==TIM2)
  /* USER CODE BEGIN TIM2_MspPostInit 0 */
  /* USER CODE END TIM2_MspPostInit 0 */
    /**TIM2 GPIO Configuration
    PA3     ------> TIM2_CH4
    GPIO_InitStruct.Pin = GPIO_PIN_3;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
        GPIO_InitStruct.Pull=GPIO_PULLUP;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /* USER CODE BEGIN TIM2_MspPostInit 1 */
  /* USER CODE END TIM2_MspPostInit 1 */
/*pwm配置函数调用*/
MX_TIM2_Init();
HAL_TIM_PWM_Start(&htim2,TIM_CHANNEL_4);
