#include "hc32_ddl.h" #include "oled.h" /******************************************************************************* * Local type definitions ('typedef') ******************************************************************************/ /******************************************************************************* * Local pre-processor symbols/macros ('#define') ******************************************************************************/ /* LED0 Port/Pin definition */ #define LED0_PORT (PortE) #define LED0_PIN (Pin06) /* LED1 Port/Pin definition */ #define LED1_PORT (PortA) #define LED1_PIN (Pin07) /* LED0~1 toggle definition */ #define LED0_TOGGLE() (PORT_Toggle(LED0_PORT, LED0_PIN)) #define LED1_TOGGLE() (PORT_Toggle(LED1_PORT, LED1_PIN)) /******************************************************************************* * Global variable definitions (declared in header file with 'extern') ******************************************************************************/ /******************************************************************************* * Local function prototypes ('static') ******************************************************************************/ /******************************************************************************* * Local variable definitions ('static') ******************************************************************************/ /** ****************************************************************************** ** \brief Initialize the system clock for the sample ** ** \param None ** ** \retval None ******************************************************************************/ static void SysClkIni(void) { en_clk_sys_source_t enSysClkSrc; stc_clk_sysclk_cfg_t stcSysClkCfg; stc_clk_xtal_cfg_t stcXtalCfg; stc_clk_mpll_cfg_t stcMpllCfg; MEM_ZERO_STRUCT(enSysClkSrc); MEM_ZERO_STRUCT(stcSysClkCfg); MEM_ZERO_STRUCT(stcXtalCfg); MEM_ZERO_STRUCT(stcMpllCfg); /* Set bus clk div. */ stcSysClkCfg.enHclkDiv = ClkSysclkDiv1; // Max 168MHz stcSysClkCfg.enExclkDiv = ClkSysclkDiv2; // Max 84MHz stcSysClkCfg.enPclk0Div = ClkSysclkDiv1; // Max 168MHz stcSysClkCfg.enPclk1Div = ClkSysclkDiv2; // Max 84MHz stcSysClkCfg.enPclk2Div = ClkSysclkDiv4; // Max 60MHz stcSysClkCfg.enPclk3Div = ClkSysclkDiv4; // Max 42MHz stcSysClkCfg.enPclk4Div = ClkSysclkDiv2; // Max 84MHz CLK_SysClkConfig(&stcSysClkCfg); /* Switch system clock source to MPLL. */ /* Use Xtal32 as MPLL source. */ stcXtalCfg.enMode = ClkXtalModeOsc; stcXtalCfg.enDrv = ClkXtalLowDrv; stcXtalCfg.enFastStartup = Enable; CLK_XtalConfig(&stcXtalCfg); CLK_XtalCmd(Enable); /* MPLL config. */ stcMpllCfg.pllmDiv = 1u; stcMpllCfg.plln =50u; stcMpllCfg.PllpDiv = 4u; stcMpllCfg.PllqDiv = 4u; stcMpllCfg.PllrDiv = 4u; CLK_SetPllSource(ClkPllSrcXTAL); CLK_MpllConfig(&stcMpllCfg); /* flash read wait cycle setting */ EFM_Unlock(); EFM_SetLatency(EFM_LATENCY_5); EFM_Lock(); /* Enable MPLL. */ CLK_MpllCmd(Enable); /* Wait MPLL ready. */ while(Set != CLK_GetFlagStatus(ClkFlagMPLLRdy)) { ; } /* Switch system clock source to MPLL. */ CLK_SetSysClkSource(CLKSysSrcMPLL); } /** ******************************************************************************* ** \brief Main function of template project ** ** \param None ** ** \retval int32_t return value, if needed ** ******************************************************************************/ int32_t main(void) { uint32_t i; stc_port_init_t stcPortInit; /* Initialize system clock*/ SysClkIni(); /*initiallize LED port*/ MEM_ZERO_STRUCT(stcPortInit); stcPortInit.enPinMode = Pin_Mode_Out; stcPortInit.enExInt = Enable; stcPortInit.enPullUp = Enable; /* LED0 Port/Pin initialization */ PORT_Init(LED0_PORT, LED0_PIN, &stcPortInit); /* LED1 Port/Pin initialization */ PORT_Init(LED1_PORT, LED1_PIN, &stcPortInit); OLED_Init(); OLED_Clear(); OLED_ShowString(10,1,"I Love You!");// OLED TEST /* I2C master polling comunication successed */ while(1) { LED1_TOGGLE(); Ddl_Delay1ms(500ul); } } /******************************************************************************* * EOF (not truncated) ******************************************************************************/ 效果图: 工程: OLED.rar (812.44 KB, 下载次数: 41) 2020-6-7 14:23 上传 点击文件名下载附件
举报
凡人8000 发表于 2020-6-8 10:12 我也刚测试了一下OLED,想实现字符向左或向右持续滚动,利用驱动库实现有限制,一行只能显示16个字符,多出 ...
she20191204 发表于 2020-6-9 07:55 你们都试用一个星期了,我的都没有收到货。论坛也不给个说法。
yljon 发表于 2020-6-9 10:20 又看见楼主的日记本啦
本版积分规则 发表回复 回帖后跳转到最后一页
人才类勋章
时间类勋章
553
3530
20
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
