[通用8051核FLASH系列] 【芯圣SDK-HC89F0541测评】+ TN9
1328|7
 楼主| 比神乐 发表于 2020-7-12 11:05 | 显示全部楼层 |阅读模式
今天搞了一下TN9,红外体温计模块。
Data:P2.7
CLK:P2.6
ACTION :P2.5
原理图:
代码:
  1. #define        ALLOCATE_EXTERN
  2. #include "HC89F0541.h"
  3. #define uchar unsigned char
  4. #define uint unsigned int
  5.
  6. void ACK_0() { P2_5=0;}  //
  7. void ACK_1() { P2_5=1;}
  8. #define DATA            P2_7
  9. #define CLOCK           P2_6
  10. float Temp;
  11. float Temp1,Temp2;
  12. unsigned char ReadData[5];
  13. //float  a,b;
  14. //-----------------------------------------------------------------------------------------
  15. //????:Delay()
  16. //?    ?:?????
  17. //-----------------------------------------------------------------------------------------
  18. void Delay(unsigned char us)  //5,7,9
  19. {
  20.   while(--us);
  21. }
  22. //-----------------------------------------------------------------------------------------
  23. //????:Delayms()
  24. //-----------------------------------------------------------------------------------------
  25. void Delayms(unsigned int ims)
  26. {
  27.   unsigned int i,j;
  28.         for(i=0;i<ims;i++)
  29.                 for(j=0;j<65;j++)
  30.                 {
  31.                         Delay(1);
  32.                 }
  33. }
  34. void TN_IRACK_EN(void)
  35. {
  36.         ACK_0();
  37.   Delay(1);
  38. }
  39. void TN_IRACK_UN(void)
  40. {
  41.         ACK_1();
  42.   Delay(1);
  43. }
  44. void TN_ReadData(unsigned char Flag)
  45. {
  46.         unsigned char i,j,k,BitState=0;
  47.         for(k=0;k<7;k++)
  48.         {
  49.                 for(j=0;j<5;j++)
  50.                 {
  51.                         for(i=0;i<8;i++)
  52.                         {
  53.                                 while(1)
  54.                                 {
  55.                                         if(CLOCK==0)
  56.                                                 break;
  57.                                         Delay(1);
  58.                                 }
  59.                                 Delay(1);
  60.                                 if(DATA==1)
  61.                                         BitState=1;
  62.                                 else
  63.                                         BitState=0;
  64.                                 ReadData[j]= ReadData[j]<<1;
  65.                                 ReadData[j]= ReadData[j]|BitState;
  66.                                 Delay(1);
  67.                                 while(1)
  68.                                 {
  69.                                         if(CLOCK==1)
  70.                                                 break;
  71.                                         Delay(1);
  72.                                 }
  73.                         }
  74.                 }
  75.                 if(ReadData[0]==Flag)
  76.                         k=8;
  77.         }
  78.         TN_IRACK_UN();
  79. }
  80. float TN_GetData(unsigned char X)
  81. {
  82.
  83.   //InitIO();
  84.         TN_ReadData(X);
  85.         Temp=(ReadData[1]<<8)|ReadData[2];
  86.         Temp=(float)Temp/16.00-273.15;
  87.         return Temp;
  88. }
  89. float TN_GetTemp(unsigned char mode)
  90. {
  91.
  92.         float T;
  93.
  94.         {
  95.                 TN_IRACK_UN();
  96.                 TN_IRACK_EN();
  97.                 if(mode==0)
  98.                 {
  99.                         T=TN_GetData(0x4c);
  100.
  101.                 }
  102.                 else
  103.                 {
  104.                         T=TN_GetData(0x66);
  105.
  106.                 }
  107.         }
  108.
  109.
  110.         return T;
  111. }
  112. /***************************************************************************************
  113.   * @实现效果        对P00端口的消抖时间进行设置,251.9375us<消抖时间<255.9375us。
  114. ***************************************************************************************/
  115. void main()
  116. {
  117. /************************************系统初始化****************************************/
  118.         CLKSWR = 0x51;                                                //选择内部高频RC为系统时钟,内部高频RC 2分频,Fosc=16MHz
  119.         CLKDIV = 0x01;                                                //Fosc 1分频得到Fcpu,Fcpu=16MHz
  120. /**********************************端口消抖初始化**************************************/
  121.   P2M7 = 0x62;                        //P27设置为上拉输入
  122.         P2M6 = 0x62;                        //P27设置为上拉输入
  123.         P2M5 = 0xC0;                        //P27设置为上拉输入
  124.
  125.         while(1)
  126.         {
  127.                 Temp1=TN_GetTemp(0);
  128.                 Temp2=TN_GetTemp(1);
  129.
  130.                 Delayms(500);
  131.         }
  132. }
效果图:
工程:
TN9.rar (50.06 KB, 下载次数: 9)
木木guainv 发表于 2020-8-7 13:55 | 显示全部楼层
代码很详细
磨砂 发表于 2020-8-7 13:56 | 显示全部楼层
感谢楼主分享
晓伍 发表于 2020-8-7 13:57 | 显示全部楼层
传感器精度如何
八层楼 发表于 2020-8-7 13:59 | 显示全部楼层
对使用环境要求高吗
 楼主| 比神乐 发表于 2020-8-7 13:59 | 显示全部楼层
传感器精度如何
手册上应该有,忘了是多少了
观海 发表于 2020-8-7 14:00 | 显示全部楼层
楼主辛苦了
 楼主| 比神乐 发表于 2020-8-7 14:01 | 显示全部楼层
对使用环境要求高吗
一般都没问题
