有没有像正点原子那样的sys.h,这样就方便位操作了
- #ifndef __SYS_H
- #define __SYS_H
- #include "hal_board.h"
- #define SYSTEM_SUPPORT_UCOS 0 //定义系统文件夹是否支持UCOS
- #define BITBAND(addr, bitnum) ((addr & 0x8000000)+0x2000000+((addr &0xFFFFF)<<5)+(bitnum<<2))
- #define MEM_ADDR(addr) *((volatile unsigned long *)(addr))
- #define BIT_ADDR(addr, bitnum) MEM_ADDR(BITBAND(addr, bitnum))
- //IO口地址映射
- #define GPIOA_ODR_Addr (GPIOA_BASE+12) //0x4001080C
- #define GPIOB_ODR_Addr (GPIOB_BASE+12) //0x40010C0C
- #define GPIOC_ODR_Addr (GPIOC_BASE+12) //0x4001100C
- #define GPIOD_ODR_Addr (GPIOD_BASE+12) //0x4001140C
- #define GPIOE_ODR_Addr (GPIOE_BASE+12) //0x4001180C
- #define GPIOF_ODR_Addr (GPIOF_BASE+12) //0x40011A0C
- #define GPIOG_ODR_Addr (GPIOG_BASE+12) //0x40011E0C
- #define GPIOA_IDR_Addr (GPIOA_BASE+8) //0x40010808
- #define GPIOB_IDR_Addr (GPIOB_BASE+8) //0x40010C08
- #define GPIOC_IDR_Addr (GPIOC_BASE+8) //0x40011008
- #define GPIOD_IDR_Addr (GPIOD_BASE+8) //0x40011408
- #define GPIOE_IDR_Addr (GPIOE_BASE+8) //0x40011808
- #define GPIOF_IDR_Addr (GPIOF_BASE+8) //0x40011A08
- #define GPIOG_IDR_Addr (GPIOG_BASE+8) //0x40011E08
- //IO口操作,只对单一的IO口!
- //确保n的值小于16!
- #define PAout(n) BIT_ADDR(GPIOA_ODR_Addr,n) //输出
- #define PAin(n) BIT_ADDR(GPIOA_IDR_Addr,n) //输入
- #define PBout(n) BIT_ADDR(GPIOB_ODR_Addr,n) //输出
- #define PBin(n) BIT_ADDR(GPIOB_IDR_Addr,n) //输入
- #define PCout(n) BIT_ADDR(GPIOC_ODR_Addr,n) //输出
- #define PCin(n) BIT_ADDR(GPIOC_IDR_Addr,n) //输入
- #define PDout(n) BIT_ADDR(GPIOD_ODR_Addr,n) //输出
- #define PDin(n) BIT_ADDR(GPIOD_IDR_Addr,n) //输入
- #define PEout(n) BIT_ADDR(GPIOE_ODR_Addr,n) //输出
- #define PEin(n) BIT_ADDR(GPIOE_IDR_Addr,n) //输入
- #define PFout(n) BIT_ADDR(GPIOF_ODR_Addr,n) //输出
- #define PFin(n) BIT_ADDR(GPIOF_IDR_Addr,n) //输入
- #define PGout(n) BIT_ADDR(GPIOG_ODR_Addr,n) //输出
- #define PGin(n) BIT_ADDR(GPIOG_IDR_Addr,n) //输入
- //Ex_NVIC_Config专用定义
- #define GPIO_A 0
- #define GPIO_B 1
- #define GPIO_C 2
- #define GPIO_D 3
- #define GPIO_E 4
- #define GPIO_F 5
- #define GPIO_G 6
- #define FTIR 1 //下降沿触发
- #define RTIR 2 //上升沿触发
- //JTAG模式设置定义
- #define JTAG_SWD_DISABLE 0X02
- #define SWD_ENABLE 0X01
- #define JTAG_SWD_ENABLE 0X00
- void Stm32_Clock_Init(u8 PLL); //时钟初始化
- void Sys_Soft_Reset(void); //系统软复位
- void Sys_Standby(void); //待机模式
- void MY_NVIC_SetVectorTable(u32 NVIC_VectTab, u32 Offset);//设置偏移地址
- void MY_NVIC_PriorityGroupConfig(u8 NVIC_Group);//设置NVIC分组
- void MY_NVIC_Init(u8 NVIC_PreemptionPriority,u8 NVIC_SubPriority,u8 NVIC_Channel,u8 NVIC_Group);//设置中断
- void Ex_NVIC_Config(u8 GPIOx,u8 BITx,u8 TRIM);//外部中断配置函数(只对GPIOA~G)
- void JTAG_Set(u8 mode);
- //以下为汇编函数
- void WFI_SET(void); //执行WFI指令
- void INTX_DISABLE(void);//关闭所有中断
- void INTX_ENABLE(void); //开启所有中断
- void MSR_MSP(u32 addr); //设置堆栈地址
- #endif
