题目:有一分数序列:2/1,3/2,5/3,8/5,13/8,21/13...求出这个数列的前20项之和。 程序分析:请抓住分子与分母的变化规律。 程序源代码: 方法一:- #!/usr/bin/python
- # -*- coding: UTF-8 -*-
- a = 2.0
- b = 1.0
- s = 0
- for n in range(1,21):
- s += a / b
- t = a
- a = a + b
- b = t
- print (s)
方法二:
- #!/usr/bin/python
- a = 2.0
- b = 1.0
- s = 0.0
- s += a / b
- b,a = a , a + b
- print (s)
- s = 0.0
- s += a / b
- b,a = a , a + b
- print (s)
方法三:
- #!/usr/bin/python
- a = 2.0
- b = 1.0
- l = []
- l.append(a / b)
- for n in range(1,20):
- b,a = a,a + b
- l.append(a / b)
- print reduce(lambda x,y: x + y,l)
实例(Python 3.x)
- #!/usr/bin/python
- from functools import reduce
- a = 2.0
- b = 1.0
- l = []
- l.append(a / b)
- b,a = a,a + b
- l.append(a / b)
- print (reduce(lambda x,y: x + y,l))
以上实例输出结果为:
32.6602607986
