- void uart_initwBaudRate(u32 bound)
- //GPIO端口设置
- GPIO_InitTypeDef GPIO_InitStructure;
- UART_InitTypeDef UART_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_UART1 | RCC_APB2Periph_GPIOA, ENABLE); //使能UART1,GPIOA时钟
- //UART 初始化设置
- UART_InitStructure.UART_BaudRate = bound;//串口波特率
- UART_InitStructure.UART_WordLength = UART_WordLength_8b;//字长为8位数据格式
- UART_InitStructure.UART_StopBits = UART_StopBits_1;//一个停止位
- UART_InitStructure.UART_Parity = UART_Parity_No;//无奇偶校验位
- UART_InitStructure.UART_HardwareFlowControl = UART_HardwareFlowControl_None;//无硬件数据流控制
- UART_InitStructure.UART_Mode = UART_Mode_Rx | UART_Mode_Tx; //收发模式
- UART_Init(UART1, &UART_InitStructure); //初始化串口1
- UART_ITConfig(UART1, UART_IT_RXIEN, ENABLE);//开启串口接受中断
- UART_Cmd(UART1, ENABLE); //使能串口1
- //UART1_TX GPIOA.9
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
- GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9
- //UART1_RX GPIOA.10初始化
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
- GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10
直接上一段串口1初始化代码,和ST的比起来,好像除了时钟初始化,其他简直可以直接复制过来,是不是灵动的固件工程师是从ST挖过来的
