[学习资料] PFC_SampleCorrection这段采样校正的原理是什么?
1332|0
 楼主| dongtianfu 发表于 2021-11-14 23:51 | 显示全部楼层 |阅读模式
AN1208_dsPIC33CK256MP508_EXT_INT_OPAMP_MCHV3.zip对应的程序
PFC_SampleCorrection(int16_t idealDuty,int16_t actualDuty,int16_t current)
    int16_t output = Q15(0.9999);
    /** Check if Ideal Duty is positive value */
    if(idealDuty > 0)
        /** Calculate ratio of actual Duty and ideal Duty */
        output = __builtin_divf(actualDuty, idealDuty) ;
    /** Check if ratio previous result is greater than 0 */
    if(output > 0)
        output = (int16_t)((__builtin_mulss(current,output)) >> 15);
    else
        output = current;
    return(output);
这段采样校正的原理是什么?希望大佬解答下。
其中/** Calculate ratio of actual Duty and ideal Duty */
