实现
- File Name: round_robin_queue.c
- Copyright:
- Version:
- Description:
- Author: EMAIL:
- Kevin.Zu zukeqiang@gmail.com
- Revision History
- DATE NAME DESCRIPTION
- 20130515 Kevin.Zu Create
- 20131205 Kevin.Zu Ported to linux
- 20211213 zukeqiang ported to tbox
- #include <string.h>
- #include <stdio.h>
- #include "round_robin_queue.h"
- #include "os_depend.h"
- #define EC20_RECV_BUF_SIZE 1024
- char ec20_recv_buf[EC20_RECV_BUF_SIZE];
- robin_queue_t ec20_recv_queue = {
- .buf = ec20_recv_buf,
- .buf_size = EC20_RECV_BUF_SIZE
- #define RS485_RECV_BUF_SIZE 1024
- char rs485_recv_buf[RS485_RECV_BUF_SIZE];
- robin_queue_t rs485_recv_queue = {
- .buf = rs485_recv_buf,
- .buf_size = RS485_RECV_BUF_SIZE
- /********************** frame buffer queue ******************************/
- void queue_init(robin_queue_t *q)
- q->front = 0;
- q->rear = 0;
- memset(q->buf,0,q->buf_size);
- int queue_length(robin_queue_t *q)
- if(q == NULL)
- return QUE_ERR;
- if(q->rear >= q->front) {
- return q->rear - q->front;
- } else {
- return q->rear + q->buf_size - q->front;
- int queue_is_full(robin_queue_t *q)
- if(q == NULL)
- return QUE_ERR;
- if(q->front == (q->rear + 1) % q->buf_size) //
- return QUE_TURN;
- else
- return QUE_FALSE;
- int queue_insert(robin_queue_t *q,char item)
- if(q == NULL)
- return QUE_ERR;
- if(queue_is_full(q))
- return QUE_ERR;
- ENTER_CRITICAL();
- q->buf[q->rear] = item;
- q->rear = (q->rear + 1) % q->buf_size; //
- EXIT_CRITICAL();
- return QUE_OK;
- int queue_insert_frame(robin_queue_t *q,char *buff,unsigned int len)
- int i;
- if(q == NULL) {
- return QUE_ERR;
- if(len > q->buf_size - queue_length(q) -1 ) {
- printf("The data length exceeds the buffer margin!\n");
- return QUE_ERR;
- for(i = 0;i < len;i ++) {
- q->buf[q->rear] = buff[i];
- ENTER_CRITICAL();
- EXIT_CRITICAL();
- return QUE_OK;
- int queue_is_empty(robin_queue_t *q)
- if(q == NULL)
- return QUE_ERR;
- if(q->front == q->rear) {
- return QUE_TURN;
- } else {
- return QUE_FALSE;
- inline char *queue_get_item(robin_queue_t *q)
- char *item;
- if(!queue_is_empty(q)) {
- item = q->buf + q->front;
- ENTER_CRITICAL();
- q->front = (q->front + 1) % q->buf_size;
- EXIT_CRITICAL();
- return item;
- } else {
- return NULL;
- int queue_del_item(robin_queue_t *q)
- if(q == NULL)
- return QUE_ERR;
- if(queue_is_empty(q))
- return QUE_ERR;
- ENTER_CRITICAL();
- EXIT_CRITICAL();
- return QUE_OK;
- int queue_add_index(robin_queue_t *q,unsigned len)
- if(q == NULL)
- return QUE_ERR;
- ENTER_CRITICAL();
- q->rear = (q->rear + len) % q->buf_size; //
- EXIT_CRITICAL();
- return QUE_OK;
- int queue_get_frame(robin_queue_t *q,char *buff)
- int i = 0;
- if(buff == NULL) {
- return QUE_ERR;
- while(!queue_is_empty(q)){
- buff[i] = *(q->buf + q->front);
- ENTER_CRITICAL();
- EXIT_CRITICAL();
- i ++;
- return i;
- ///////////////////////////////////////////// test ////////////////////////////////////
- #define TEST_BUF_SIZE 1000
- char test_buf[TEST_BUF_SIZE];
- robin_queue_t test_queue = {
- .buf = test_buf,
- .buf_size = TEST_BUF_SIZE
- void _test_queue(void)
- int i;
- char *item = NULL;
- char tbuf[200];
- for(i = 0;i < 200;i ++) {
- tbuf[i] = 100 + i;
- queue_init(&test_queue);
- for(i = 1;i < test_queue.buf_size/2;i ++) {
- queue_insert(&test_queue,(char)i);
- printf("====len:%d\n",queue_length(&test_queue));
- while(!queue_is_empty(&test_queue)) {
- item = queue_get_item(&test_queue);
- if(item != NULL) {
- printf("item:%d ",*item);
- printf("\n\n");
- int it = test_queue.buf_size/2;
- while(!queue_is_full(&test_queue)) {
- printf("insert:%d ",it);
- queue_insert(&test_queue,(char)it);
- it ++;
- printf("\n\n");
- queue_insert_frame(&test_queue,tbuf,200);
- printf("==++++==len:%d\n",queue_length(&test_queue));
- printf("==----==len:%d\n",queue_length(&test_queue));
