按键扫描函数-(当一个按键按下时屏蔽其他按键)
 楼主| skw168 发表于 2022-2-17 14:57 | 显示全部楼层 |阅读模式
#define POWER_KEY_PORT                        GPIOA
#define POWER_KEY_PIN                        GPIO_Pin_1
#define GET_POWER_KEY                        GPIO_ReadInputDataBit(POWER_KEY_PORT, POWER_KEY_PIN)
#define FUN_KEY_PORT                        GPIOA
#define FUN_KEY_PIN                         GPIO_Pin_6
#define GET_FUN_KEY                         GPIO_ReadInputDataBit(FUN_KEY_PORT, FUN_KEY_PIN)
#define MEM_KEY_PORT                        GPIOA
#define MEM_KEY_PIN                         GPIO_Pin_7
#define GET_MEM_KEY                         GPIO_ReadInputDataBit(MEM_KEY_PORT, MEM_KEY_PIN)
#define CNT_SHORT                                5
#define CNT_LONG                                50
#define NONE_PRESS                                 0x00
#define POWER_PRESS                                0x01
#define FUN_PRESS                                0x02
#define MEM_PRESS                                0x04
struct MeasSet_type MeasSet;
struct StoreSet_type StoreSet;
struct LookStoreSet_type LookStoreSet;
struct RpmValue_type RpmValue;
enum KeyStatus_type
        RESET_KEY_CHECK = 0,
        POWER_LONG_CHECK,
        FUN_LONG_CHECK,
        MEM_LONG_CHECK,
        ERROR_KEY
}key_status;
static struct
        unsigned ShortPower                        :        1;
        unsigned LongPower                        :        1;
        unsigned ReleasePower                :        1;
        unsigned ShortMeas0                        :        1;
        unsigned ReleaseMeas0                :        1;
        unsigned ShortMeas1                        :        1;
        unsigned ReleaseMeas1                :        1;
        unsigned ShortMode                        :        1;
        unsigned LongMode                        :        1;
        unsigned ShortMaxMin                :        1;
        unsigned LongMaxMin                        :        1;
        unsigned ShortStore                        :        1;
        unsigned LongStore                        :        1;
        unsigned ShortUnit                        :        1;
        unsigned LongUnit                        :        1;
}KeyFlag;
//static enum KeyStatus_type key_status;
void KEY_SCAN(void)
        unsigned char buff_key;
        static unsigned char cnt_press[3];
        static unsigned int cnt_auto_off;
        buff_key = NONE_PRESS;
        if(GET_POWER_KEY == 0)
                buff_key |= POWER_PRESS;
        if(GET_FUN_KEY == 0)
                buff_key |= FUN_PRESS;
        if(GET_MEM_KEY == 0)
                buff_key |= MEM_PRESS;
        switch(key_status)
                case RESET_KEY_CHECK:
                                if(buff_key == POWER_PRESS)
                                        if(++cnt_press[0] >= CNT_SHORT)
                                                cnt_press[0] = 0;
                                                key_status = POWER_LONG_CHECK;
                                                KeyFlag.ShortPower = 1;
                                else if(buff_key == FUN_PRESS)
                                        if(++cnt_press[1] >= CNT_SHORT)
                                                cnt_press[1] = 0;
                                                key_status = FUN_LONG_CHECK;
                                                KeyFlag.ShortMode = 1;
                                else if(buff_key == MEM_PRESS)
                                        if(++cnt_press[2] >= CNT_SHORT)
                                                cnt_press[2] = 0;
                                                key_status = MEM_LONG_CHECK;
                                                KeyFlag.ShortMaxMin = 1;
                                else
                                        cnt_press[0] = 0;
                                        cnt_press[1] = 0;
                                        cnt_press[2] = 0;
                        }break;
                case POWER_LONG_CHECK:
                                        if(cnt_press[0] < CNT_LONG)
                                                cnt_press[0] ++;
                                                if(cnt_press[0] == CNT_LONG)
                                                        KeyFlag.LongPower = 1;
                                else if(buff_key == NONE_PRESS)
                                        cnt_press[0] = 0;
                                        key_status = RESET_KEY_CHECK;
                                        KeyFlag.ReleasePower = 1;
                                else
                                        key_status = ERROR_KEY;
                        }break;
                case FUN_LONG_CHECK:
                                        if(cnt_press[1] < CNT_LONG)
                                                cnt_press[1] ++;
                                                if(cnt_press[1] == CNT_LONG)
                                        cnt_press[1] = 0;
                                else
                        }break;
                case MEM_LONG_CHECK:
                                        if(cnt_press[2] < CNT_LONG)
                                                cnt_press[2] ++;
                                                if(cnt_press[2] == CNT_LONG)
                                        cnt_press[2] = 0;
                                else
                        }break;
                case ERROR_KEY:
                        }break;
                default:         key_status = RESET_KEY_CHECK;        break;
//        if(buff_key == NONE_PRESS)
//                if(++cnt_auto_off >= 7500)
//                        cnt_auto_off = 0;
//                        POWER_OFF;
//        else
湖畔群思 发表于 2022-2-19 11:52 | 显示全部楼层
不觉明历
xyz549040622 发表于 2022-2-21 21:35 | 显示全部楼层
楼主的意思是不会支持组合按键吗?不明觉厉
快速回复 返回顶部 返回列表
