[全新] 5V多节锂电(2~4节)同步升压管理芯片ZCC6983
 楼主| SWdianzi 发表于 2022-3-24 14:25 | 显示全部楼层 |阅读模式
特性
■ 3.0V to 5.5V Operating Input Voltage
■ Up to 26V Sustainable Voltage
■ Up to 2A Configurable Charge Current for Battery
with 2~4 Cells in Series
■ Configurable Input Voltage Limit
■ Charge Status Indication
■ Constant Voltage Selectable
■ Programmable Charge Timeout
■ Thermal Regulation Protection
■ External Shutdown Function
■ Input Voltage UVLO and OVP
■ Over Temperature Protection
■ Output Short Cir cuit Protec tion Normal
Synchronous Boost Operation When Battery
Removed
应用
■ Power Bank
■ Cellular Telephones,MP3Players,MP4 Players
■ PSP Game Players,NDS game Players
■ Notebook
描述
ZCC6983 is a highly integrated synchronous boost
charger IC for Lithium-ion batteries with four cells in
series . The charge current up to 2A can be
programmed by using the external resistor for different
portable applications.
Robust protections include input over-voltage
protection (OVP), battery OVP, battery short protection,
thermal shut down, battery temperature monitor, a
configurable timer to prevent prolonged charging of a
dead battery.
快速回复 返回顶部 返回列表
