[MM32软件] 定时器1ch4(PA11)产生PWM ,在STM32正常,MM32卡死,是什么原因?
 楼主| zhangpeizhong 发表于 2022-7-8 09:32 | 显示全部楼层 |阅读模式
(使用MM32库)
void Tim1_Init()
  /* TIM1 Peripheral Configuration */
        TIM_TimeBaseInitTypeDef  TIM1_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM1_OCInitStructure;
        TIM_BDTRInitTypeDef TIM1_BDTRInitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE);
         /* TIM1 clock enable */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
    TIM_DeInit(TIM1);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Time Base configuration */
  TIM1_TimeBaseStructure.TIM_Prescaler = 10;//0x0;                分频
  TIM1_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM1_TimeBaseStructure.TIM_Period = 6500-1;  //6500-1? 3600-1;
  TIM1_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM1_TimeBaseStructure.TIM_RepetitionCounter = 0x0;
  TIM_TimeBaseInit(TIM1,&TIM1_TimeBaseStructure);
  // Channel 4 and 4 Configuration in PWM mode
  TIM1_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  TIM1_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM1_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM1_OCInitStructure.TIM_Pulse = 1800;
  TIM1_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM1_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  TIM1_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM1_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM1_OCInitStructure.TIM_Pulse = 1800 ;        //50%
  TIM_OC4PreloadConfig(TIM1, TIM_OCPreload_Enable);  //使能TIMx在CCR2上的预装载寄存器
  TIM_OC4Init(TIM1,&TIM1_OCInitStructure);
  TIM_Cmd(TIM1,ENABLE);
  TIM_CtrlPWMOutputs(TIM1,ENABLE); //TIM1_CH4 PWM输出
[url=]更多操作[/url]
onlycook 发表于 2022-7-14 14:58 来自手机 | 显示全部楼层
可能是不兼容吗
huquanz711 发表于 2022-7-15 07:41 来自手机 | 显示全部楼层
兼容不兼容啊!
laocuo1142 发表于 2022-7-18 10:33 | 显示全部楼层
功能应该是兼容的,检查一下配置
tpgf 发表于 2022-8-1 18:45 | 显示全部楼层
外部晶振一样的吗
qcliu 发表于 2022-8-1 19:06 | 显示全部楼层
能正常初始化吗
drer 发表于 2022-8-1 19:13 | 显示全部楼层
有修改哪些地方了吗
coshi 发表于 2022-8-1 19:28 | 显示全部楼层
可能兼容性不够好
kxsi 发表于 2022-8-1 19:34 | 显示全部楼层
看看引脚是否可以完全兼容
wiba 发表于 2022-8-1 19:46 | 显示全部楼层
存储容量是兼容的吗
Bowclad 发表于 2022-9-16 21:09 | 显示全部楼层
存储容量是兼容的吗
快速回复 返回顶部 返回列表
