[全新] ZCC575A数字温度传感器替代LM75
 楼主| SWdianzi 发表于 2022-7-14 15:46 | 显示全部楼层 |阅读模式
Features
Temperature accuracy
±1℃ from -20℃~ 80℃
±2℃ from -40℃~ 125℃
Low power consumption
4.5uA shutdown current at VDD=5.0V
125uA continuous conversion current
2.2~8.0V ultra-wide operation supply voltage
High PSR in temperature monitoring
I2C &SMBus digital communication interface
LM75 function and register compatible
0.0625℃ temperature resolution
Support up to 32 devices by A0/A1/A2 pin
hardware configuration
OS pin open-drain alert and interrupt
multi-function
OS output polarity configuration
Embedded one-shot conversion mode
Applications
Home appliance thermal control
Server board temperature monitoring
Thermostat control
Environmental temperature monitoring
Electronic equipment and facilities
General system thermal management
Description
The ZCC575 is a digital-type high-accurate on-chip
integrated temperature sensor chip with an
integrated high resolution sigma-delta converter and
I2C/SMBus digital interface. It is register and function
compatible with industrial standard LM75 digital
temperature sensor. ZCC575 is available in E-MSOP8
package, it offers hardware pin and firmware
compatibility to easy upgrade from LM75x design.
Digital communication 2-wire interface which
operates up to 400KHz of fast mode and 2.5MHz of
high-speed mode. There are 3 hardware address pins,
A0/A1/A2, which could configure the I2C address
externally. The ZCC575 has a dedicated
over-temperature shutdown output (OS) pin with
programmable higher or lower limit in hysteresis.
The OS pin could also be output polarity reverse by
configure POL register bit setting in configuration
register. There is a consecutive fault measurements
function which could be programmed by
1/2/3/4counts. The OS pin will enabled if the
temperature conversion data is over the pre-set
limitation value continuously, and satisfies the FQ[1:0]
resister setting
快速回复 返回顶部 返回列表
