小华单片机HC32F460的跑官方例程时会发送不成功
2182|6
 楼主| luckyren 发表于 2023-3-2 10:38 | 显示全部楼层 |阅读模式
目前在调试HC32F460时会卡在如下代码:在while (CAN_GetStatus(CAN_UNIT, CAN_FLAG_STB_TX) == RESET) { },哪位大佬可以指点一下吗?static void CanTx(void)
    uint8_t i;
    static uint8_t u8Data;
    for (i = 0U; i < CAN_TX_DATA_SIZE; i++) {
        m_stcTx1.au8Data[i] = u8Data++;
        m_stcTx2.au8Data[i] = u8Data++;
        m_stcTx3.au8Data[i] = u8Data++;
    /* Frame with CAN_ID1 */
    m_stcTx1.u32Ctrl = 0x0UL;
    m_stcTx1.u32ID   = CAN_TX_ID1;
    m_stcTx1.IDE     = CAN_TX_ID1_IDE;
    m_stcTx1.DLC     = CAN_TX_DLC;
    (void)CAN_FillTxFrame(CAN_UNIT, CAN_TX_BUF_PTB, &m_stcTx1);
    /* Start PTB TX */
    CAN_StartTx(CAN_UNIT, CAN_TX_REQ_PTB);
    /* Check transmission end. */
    while (CAN_GetStatus(CAN_UNIT, CAN_FLAG_PTB_TX) == RESET) { }
    CAN_ClearStatus(CAN_UNIT, CAN_FLAG_PTB_TX);
    /* Frame with CAN_ID2 */
    m_stcTx2.u32Ctrl = 0x0UL;
    m_stcTx2.u32ID   = CAN_TX_ID2;
    m_stcTx2.IDE     = CAN_TX_ID2_IDE;
    m_stcTx2.DLC     = CAN_TX_DLC;
    (void)CAN_FillTxFrame(CAN_UNIT, CAN_TX_BUF_STB, &m_stcTx2);
    /* Frame with CAN_ID3 */
    m_stcTx3.u32Ctrl = 0x0UL;
    m_stcTx3.u32ID   = CAN_TX_ID3;
    m_stcTx3.IDE     = CAN_TX_ID3_IDE;
    m_stcTx3.DLC     = CAN_TX_DLC;
    (void)CAN_FillTxFrame(CAN_UNIT, CAN_TX_BUF_STB, &m_stcTx3);
    /* Start STB TX */
    CAN_StartTx(CAN_UNIT, CAN_TX_REQ_STB_ALL);
    CAN_ClearStatus(CAN_UNIT, CAN_FLAG_STB_TX);
微信13267226716 发表于 2023-3-3 09:02 | 显示全部楼层
搞定了没
热任务人 发表于 2023-12-4 10:37 | 显示全部楼层
老哥你怎么搞定的,加下联系方式qq1098140630
duo点 发表于 2023-12-7 15:35 | 显示全部楼层
检查硬件连接是否正确,包括电源、信号线等。
laocuo1142 发表于 2023-12-7 15:36 | 显示全部楼层
可能是串口配置问题
flycamelaaa 发表于 2023-12-7 15:36 | 显示全部楼层
如果在调试模式下运行程序,可能会影响数据传输。尝试关闭调试模式或使用单独的串口进行调试。
chenjun89 发表于 2023-12-8 20:51 来自手机 | 显示全部楼层
发送不成功?
