HC32F460芯片片内温度使用HRC时钟源,读取温度失败
325|1
林木111 发表于 2025-10-9 14:34 | 显示全部楼层 |阅读模式
HC32F460芯片系统时钟使用HRC后,片内温度使用HRC时钟源,读取温度失败
代码如下,希望各位大佬提供一下帮助,谢谢谢谢
__WEAKDEF void BSP_CLK_Init(void)
    //stc_clock_xtal_init_t     stcXtalInit;
    stc_clock_pll_init_t      stcMpllInit;
    //GPIO_AnalogCmd(BSP_XTAL_PORT, BSP_XTAL_PIN, ENABLE);
    //(void)CLK_XtalStructInit(&stcXtalInit);
    (void)CLK_PLLStructInit(&stcMpllInit);
    /* Set bus clk div. */
    CLK_SetClockDiv(CLK_BUS_CLK_ALL, (
        CLK_HCLK_DIV1 |     // 200MHz
        CLK_EXCLK_DIV2 |    // 100MHz
        CLK_PCLK0_DIV1 |    // 200MHz
        CLK_PCLK1_DIV2 |    // 100MHz
        CLK_PCLK2_DIV4 |    // 50MHz
        CLK_PCLK3_DIV4 |    // 50MHz
        CLK_PCLK4_DIV2      // 100MHz
    /* TODO. 使能HRC并等待稳定 */
    (void)CLK_HrcCmd(ENABLE);
    while (SET != CLK_GetStableStatus(CLK_STB_FLAG_HRC)) {
        ; // 等待HRC稳定
    /* MPLL config (HRC / pllmDiv * plln / PllpDiv = 200M). */
    stcMpllInit.PLLCFGR = 0UL;
    stcMpllInit.PLLCFGR_f.PLLM = 2UL - 1UL;
    stcMpllInit.PLLCFGR_f.PLLN = 50UL - 1UL;
    stcMpllInit.PLLCFGR_f.PLLP = 2UL - 1UL;
    stcMpllInit.PLLCFGR_f.PLLQ = 2UL - 1UL;
    stcMpllInit.PLLCFGR_f.PLLR = 2UL - 1UL;
    stcMpllInit.u8PLLState = CLK_PLL_ON;
    stcMpllInit.PLLCFGR_f.PLLSRC = CLK_PLL_SRC_HRC;//TODO:改内部时钟 16MHz
    (void)CLK_PLLInit(&stcMpllInit);
    /* Wait MPLL ready. */
    while (SET != CLK_GetStableStatus(CLK_STB_FLAG_PLL)) {
    /* sram init include read/write wait cycle setting */
    SRAM_SetWaitCycle(SRAM_SRAMH, SRAM_WAIT_CYCLE0, SRAM_WAIT_CYCLE0);
    SRAM_SetWaitCycle((SRAM_SRAM12 | SRAM_SRAM3 | SRAM_SRAMR), SRAM_WAIT_CYCLE1, SRAM_WAIT_CYCLE1);
    /* flash read wait cycle setting */
    (void)EFM_SetWaitCycle(EFM_WAIT_CYCLE5);
    /* 3 cycles for 126MHz ~ 200MHz */
    GPIO_SetReadWaitCycle(GPIO_RD_WAIT3);
    /* Switch driver ability */
    (void)PWC_HighSpeedToHighPerformance();
    /* Switch system clock source to MPLL. */
    CLK_SetSysClockSrc(CLK_SYSCLK_SRC_PLL);
    /* Reset cache ram */
    EFM_CacheRamReset(ENABLE);
    EFM_CacheRamReset(DISABLE);
    /* Enable cache */
    EFM_CacheCmd(ENABLE);
片内温度初始化代码如下
#define OTS_CLK_SEL                     (OTS_CLK_HRC)
/* OTS parameters, slope K and offset M. Different chip, different parameters. */
#define OTS_HRC_K                       (3002.59F)
#define OTS_HRC_M                       (27.92F)
/* Timeout value. */
#define OTS_TIMEOUT_VAL                 (10000U)
* @brief  OTS initialization configuration.
* @param  None
* @retval None
static void OtsInitConfig(void)
    stc_ots_init_t stcOTSInit;
    (void)OTS_StructInit(&stcOTSInit);
    stcOTSInit.u16ClockSrc = OTS_CLK_SEL;
    stcOTSInit.f32SlopeK   = OTS_HRC_K;
    stcOTSInit.f32OffsetM  = OTS_HRC_M;
    /* 1. Enable OTS peripheral clock. */
    FCG_Fcg3PeriphClockCmd(FCG3_PERIPH_OTS, ENABLE);
    /* 2. Initialize OTS. */
    (void)OTS_Init(&stcOTSInit);
* @brief  OTS clock configuration.
* @param  None
* @retval None
static void OtsClockConfig(void)
    /* 1. Enable HRC for OTS. */
    /* 2. Enable XTAL32 when clock source of OTS is HRC. */
    (void)CLK_Xtal32Cmd(ENABLE);
    /* Enable LRC for OTS. */
    (void)CLK_LrcCmd(ENABLE);
系统主频太高,加大OTS_TIMEOUT_VAL的值,测试读取温度正常  发表于 2025-10-9 17:21
