目前在调试HC32F460时会卡在如下代码:while (CAN_GetStatus(CAN_UNIT, CAN_FLAG_STB_TX) == RESET) { },有人指点一下吗?
- static void CanTx(void)
- uint8_t i;
- static uint8_t u8Data;
- for (i = 0U; i < CAN_TX_DATA_SIZE; i++) {
- m_stcTx1.au8Data[i] = u8Data++;
- m_stcTx2.au8Data[i] = u8Data++;
- m_stcTx3.au8Data[i] = u8Data++;
- /* Frame with CAN_ID1 */
- m_stcTx1.u32Ctrl = 0x0UL;
- m_stcTx1.u32ID = CAN_TX_ID1;
- m_stcTx1.IDE = CAN_TX_ID1_IDE;
- m_stcTx1.DLC = CAN_TX_DLC;
- (void)CAN_FillTxFrame(CAN_UNIT, CAN_TX_BUF_PTB, &m_stcTx1);
- /* Start PTB TX */
- CAN_StartTx(CAN_UNIT, CAN_TX_REQ_PTB);
- /* Check transmission end. */
- while (CAN_GetStatus(CAN_UNIT, CAN_FLAG_PTB_TX) == RESET) { }
- CAN_ClearStatus(CAN_UNIT, CAN_FLAG_PTB_TX);
- /* Frame with CAN_ID2 */
- m_stcTx2.u32Ctrl = 0x0UL;
- m_stcTx2.u32ID = CAN_TX_ID2;
- m_stcTx2.IDE = CAN_TX_ID2_IDE;
- m_stcTx2.DLC = CAN_TX_DLC;
- (void)CAN_FillTxFrame(CAN_UNIT, CAN_TX_BUF_STB, &m_stcTx2);
- /* Frame with CAN_ID3 */
- m_stcTx3.u32Ctrl = 0x0UL;
- m_stcTx3.u32ID = CAN_TX_ID3;
- m_stcTx3.IDE = CAN_TX_ID3_IDE;
- m_stcTx3.DLC = CAN_TX_DLC;
- (void)CAN_FillTxFrame(CAN_UNIT, CAN_TX_BUF_STB, &m_stcTx3);
- /* Start STB TX */
- CAN_StartTx(CAN_UNIT, CAN_TX_REQ_STB_ALL);
- while (CAN_GetStatus(CAN_UNIT, CAN_FLAG_STB_TX) == RESET) { }
- CAN_ClearStatus(CAN_UNIT, CAN_FLAG_STB_TX);
