Qualcomm QCA9880/DR600VX/DR900VX/network card/3x3 MIMO/
 楼主| wallysj 发表于 2023-4-13 17:14 | 显示全部楼层 |阅读模式
DR600VX and DR900VX are two network cardswith the QCA9880 chipset. These network cards aredesigned to provide reliable and high-speed wireless connectivity for various applications,including business, hospitality, and residential environments.
The QCA9880 chipset is a highly network(WLAN) system-on-chip (SoC) integrated solution that offers high-performancewireless connectivity with support for 802.11ac and 802.11n standards. Itfeatures three-stream MIMO technology, which allows for faster data rates andincreased range. The chipset also supports beamforming, which improves signalquality and reliability.
The DR600VX is a dual-band network cardthat operates on both 2.4GHz and 5GHz frequencies, providing a total wirelessthroughput of up to 600Mbps. It comes equipped with two external high-gainantennas.
On the other hand, the DR900VX is adual-band network card, providing a total wireless throughput of up to 900Mbps.It features three external high-gain antennas.
Both network card feature advanced securityfeatures, including WPA/WPA2 encryption, MAC filtering, and VLAN support. They alsocome with a web-based management interface for easy configuration and monitoringof the network.
In summary, DR600VX and DR900VX withQCA9880 are high-performance network card designed to deliver reliable and fastwireless connectivity for various applications. They feature the latestwireless technologies, advanced security features, and easy-to-use managementinterfaces.
快速回复 返回顶部 返回列表
