[全新] ZCC2213A锂电池均衡芯片完全替代HY2213A
 楼主| 发表于 2023-4-21 17:42 | 显示全部楼层 |阅读模式
1. General Description
The series of ZCC2213 is created for multi-cell battery packs to single-cell lithium-ion battery
Charge balance control, electrical level monitoring ICs and it also comprises high-accuracy
voltage detection circuit and delay circuit.
2. Feature
ZCC2213 series IC equips with the following features:
(1) High Precision Voltage Detection Circuit
 Overcharge detection voltage 4.000~4.500V Precision: ±25mV
 Overcharge release voltage 3.800~4.500V Precision: ±35mV
 Standby detection voltage 2.70V Precision: ±15%
 Standby release voltage 2.70V Precision: ±15%
(2) Delay times are generated by an internal circuit (external capacitors are unnecessary).
(3) Low consumption current
 Operation mode Typ. value 2.5μA, max. value: 3.5μA (VDD=3.9V)
 Standby mode Max. value:0.5μA (VDD=2.7V)
(4) Wide operation temperature range: -40℃~ +85℃
(5) Small package: SOT-23-6
(6) The series are Halogen-free, green package
3. Application
 Multi-cell Li-ion rechargeable battery packs
快速回复 返回顶部 返回列表
