各位好,雅特力读保护函数是那个呀?
以下是STM32的读保护函数,请各位大佬帮改改
- uint32_t Flash_EnableReadProtection(void) //读保护
- /* Returns the FLASH Read Protection level. */
- if( FLASH_OB_GetRDP() == RESET )
- /* Unlock the Option Bytes */
- FLASH_OB_Unlock();
- /* Sets the read protection level. */
- FLASH_OB_RDPConfig(OB_RDP_Level_1);
- /* Start the Option Bytes programming process. */
- if (FLASH_OB_Launch() != FLASH_COMPLETE)
- /* Disable the Flash option control register access (recommended to protect
- the option Bytes against possible unwanted operations) */
- FLASH_OB_Lock();
- /* Error: Flash read unprotection failed */
- return (2);
- FLASH_OB_Lock();
- /* Read Protection successfully enable */
- return (1);
- return(0);
