Description
The ZCC1005Q is a high voltage, synchronous
step-down controller operates over a wide range input
voltage 9V to 100V. The ZCC1005Q delivers 5A
continuous load current with up to 96% efficiency.
The ZCC1005Q operates with fixed frequency peak
current control with built-in compensation eliminates the
need for external components. Cycle-by-cycle current
limit in high-side MOSFET protects the converter in an
overload condition. Hiccup mode protection is triggered
if the over-current condition has persisted for longer
than the present time. The ZCC1005Q exhibits
protection features that protect the load from faults like
under-voltage,over-current and over-temperature.
The ZCC1005Q is available in an QFN-20.
Features
9V to 100V input voltage range
5A continuous output current
96% Peak Efficiency
500µA operating quiescent current
Peak Current mode control
100V 20-mΩ high-side and low-side MOSFET
150 kHz Fixed Frequency
Internal compensation for ease of use
Up to 91% duty cycle
0.8V voltage reference
9µA shutdown current
150ms Hiccup mode short circuit protection
Thermal shutdown Function
QFN-20 package
Applications
Charger in vehicle
Battery Chargers
Power adapter
