[超级CRC计算器] CRC32R_EDB88320_FFFFFFFF_00000000源码(www.hotcrc.com自动生成)
310|0
 楼主| hotpower 发表于 2023-9-21 10:14 | 显示全部楼层 |阅读模式
  1. /*------------------------------------------------------------------------------
  2.    本C语言核心代码由菜农HotPower@163.com的超级CRC计算器自动生成
  3.    Copyright 1996-2022 HotPower Software, Inc.
  4.    菜农HotPower[url=home.php?mod=space&uid=516618]@163.com[/url] 2023年9月21日 10:09:42 于西安雁塔菜地
  5. ------------------------------------------------------------------------------*/
  6. //CRC单表大表表格:
  7. const unsigned long CRC32R_EDB88320_Table[256] = {//特别注意Keil C51请用code替换const
  8.   0x00000000L,0x77073096L,0xEE0E612CL,0x990951BAL,0x076DC419L,0x706AF48FL,0xE963A535L,0x9E6495A3L,
  9.   0x0EDB8832L,0x79DCB8A4L,0xE0D5E91EL,0x97D2D988L,0x09B64C2BL,0x7EB17CBDL,0xE7B82D07L,0x90BF1D91L,
  10.   0x1DB71064L,0x6AB020F2L,0xF3B97148L,0x84BE41DEL,0x1ADAD47DL,0x6DDDE4EBL,0xF4D4B551L,0x83D385C7L,
  11.   0x136C9856L,0x646BA8C0L,0xFD62F97AL,0x8A65C9ECL,0x14015C4FL,0x63066CD9L,0xFA0F3D63L,0x8D080DF5L,
  12.   0x3B6E20C8L,0x4C69105EL,0xD56041E4L,0xA2677172L,0x3C03E4D1L,0x4B04D447L,0xD20D85FDL,0xA50AB56BL,
  13.   0x35B5A8FAL,0x42B2986CL,0xDBBBC9D6L,0xACBCF940L,0x32D86CE3L,0x45DF5C75L,0xDCD60DCFL,0xABD13D59L,
  14.   0x26D930ACL,0x51DE003AL,0xC8D75180L,0xBFD06116L,0x21B4F4B5L,0x56B3C423L,0xCFBA9599L,0xB8BDA50FL,
  15.   0x2802B89EL,0x5F058808L,0xC60CD9B2L,0xB10BE924L,0x2F6F7C87L,0x58684C11L,0xC1611DABL,0xB6662D3DL,
  16.   0x76DC4190L,0x01DB7106L,0x98D220BCL,0xEFD5102AL,0x71B18589L,0x06B6B51FL,0x9FBFE4A5L,0xE8B8D433L,
  17.   0x7807C9A2L,0x0F00F934L,0x9609A88EL,0xE10E9818L,0x7F6A0DBBL,0x086D3D2DL,0x91646C97L,0xE6635C01L,
  18.   0x6B6B51F4L,0x1C6C6162L,0x856530D8L,0xF262004EL,0x6C0695EDL,0x1B01A57BL,0x8208F4C1L,0xF50FC457L,
  19.   0x65B0D9C6L,0x12B7E950L,0x8BBEB8EAL,0xFCB9887CL,0x62DD1DDFL,0x15DA2D49L,0x8CD37CF3L,0xFBD44C65L,
  20.   0x4DB26158L,0x3AB551CEL,0xA3BC0074L,0xD4BB30E2L,0x4ADFA541L,0x3DD895D7L,0xA4D1C46DL,0xD3D6F4FBL,
  21.   0x4369E96AL,0x346ED9FCL,0xAD678846L,0xDA60B8D0L,0x44042D73L,0x33031DE5L,0xAA0A4C5FL,0xDD0D7CC9L,
  22.   0x5005713CL,0x270241AAL,0xBE0B1010L,0xC90C2086L,0x5768B525L,0x206F85B3L,0xB966D409L,0xCE61E49FL,
  23.   0x5EDEF90EL,0x29D9C998L,0xB0D09822L,0xC7D7A8B4L,0x59B33D17L,0x2EB40D81L,0xB7BD5C3BL,0xC0BA6CADL,
  24.   0xEDB88320L,0x9ABFB3B6L,0x03B6E20CL,0x74B1D29AL,0xEAD54739L,0x9DD277AFL,0x04DB2615L,0x73DC1683L,
  25.   0xE3630B12L,0x94643B84L,0x0D6D6A3EL,0x7A6A5AA8L,0xE40ECF0BL,0x9309FF9DL,0x0A00AE27L,0x7D079EB1L,
  26.   0xF00F9344L,0x8708A3D2L,0x1E01F268L,0x6906C2FEL,0xF762575DL,0x806567CBL,0x196C3671L,0x6E6B06E7L,
  27.   0xFED41B76L,0x89D32BE0L,0x10DA7A5AL,0x67DD4ACCL,0xF9B9DF6FL,0x8EBEEFF9L,0x17B7BE43L,0x60B08ED5L,
  28.   0xD6D6A3E8L,0xA1D1937EL,0x38D8C2C4L,0x4FDFF252L,0xD1BB67F1L,0xA6BC5767L,0x3FB506DDL,0x48B2364BL,
  29.   0xD80D2BDAL,0xAF0A1B4CL,0x36034AF6L,0x41047A60L,0xDF60EFC3L,0xA867DF55L,0x316E8EEFL,0x4669BE79L,
  30.   0xCB61B38CL,0xBC66831AL,0x256FD2A0L,0x5268E236L,0xCC0C7795L,0xBB0B4703L,0x220216B9L,0x5505262FL,
  31.   0xC5BA3BBEL,0xB2BD0B28L,0x2BB45A92L,0x5CB36A04L,0xC2D7FFA7L,0xB5D0CF31L,0x2CD99E8BL,0x5BDEAE1DL,
  32.   0x9B64C2B0L,0xEC63F226L,0x756AA39CL,0x026D930AL,0x9C0906A9L,0xEB0E363FL,0x72076785L,0x05005713L,
  33.   0x95BF4A82L,0xE2B87A14L,0x7BB12BAEL,0x0CB61B38L,0x92D28E9BL,0xE5D5BE0DL,0x7CDCEFB7L,0x0BDBDF21L,
  34.   0x86D3D2D4L,0xF1D4E242L,0x68DDB3F8L,0x1FDA836EL,0x81BE16CDL,0xF6B9265BL,0x6FB077E1L,0x18B74777L,
  35.   0x88085AE6L,0xFF0F6A70L,0x66063BCAL,0x11010B5CL,0x8F659EFFL,0xF862AE69L,0x616BFFD3L,0x166CCF45L,
  36.   0xA00AE278L,0xD70DD2EEL,0x4E048354L,0x3903B3C2L,0xA7672661L,0xD06016F7L,0x4969474DL,0x3E6E77DBL,
  37.   0xAED16A4AL,0xD9D65ADCL,0x40DF0B66L,0x37D83BF0L,0xA9BCAE53L,0xDEBB9EC5L,0x47B2CF7FL,0x30B5FFE9L,
  38.   0xBDBDF21CL,0xCABAC28AL,0x53B39330L,0x24B4A3A6L,0xBAD03605L,0xCDD70693L,0x54DE5729L,0x23D967BFL,
  39.   0xB3667A2EL,0xC4614AB8L,0x5D681B02L,0x2A6F2B94L,0xB40BBE37L,0xC30C8EA1L,0x5A05DF1BL,0x2D02EF8DL
  40. };
  41. //CRC单表大表查表算法:
  42. unsigned long GetCRC32R_EDB88320_FFFFFFFF_FFFFFFFF_Table(unsigned char *crcBuff, unsigned int crcLen) {
  43. unsigned int i;
  44. unsigned long crc = 0xFFFFFFFF;//初值
  45.   for(i = 0; i < crcLen; i ++){
  46.     crc = (crc >> 8) ^ CRC32R_EDB88320_Table[(crc & 0xFF) ^ crcBuff[i]];
  47.   }
  48.   crc ^= 0xFFFFFFFF;//出值
  49.   return crc;
  50. }
  51. int main(){
  52. //数据格式:HEX
  53. const unsigned char dataTable[] = {
  54.   0x01, 0x23, 0x45, 0x67, 0x89, 0xAB, 0xCD, 0xEF
  55. };//特别注意Keil C51请用code替换const
  56. unsigned long crc;
  57.   crc = GetCRC32R_EDB88320_FFFFFFFF_FFFFFFFF_Table((unsigned char *)dataTable, sizeof(dataTable));
  58. //表格函数返回crc=0x28C7D1AE,与HotWC3运算相同
  59.   while(crc | 1);//死循环,请在此处设置断点,验证函数返回值crc是否正确!!!
  60.   return 0;
  61. }
个人签名:[url=http://www.21ic.com/tools/HotWC3_V1.23.html]
1460
