- #include <stdio.h>
- #include <REG52.H>
- #ifdef MONITOR51
- char code reserve [3] _at_ 0x23;
- #endif
- typedef unsigned char uint8_t;
- typedef unsigned int uint16_t;
- typedef unsigned long uint32_t;
- code uint32_t CRC32Array[8] = {//菜农HotPower@163.com
- //全局数组,在Flash里
- 0x55555555,//头数据,为注册机提供搜索位置,改写即篡改非零
- 0xAAAAAAAA,//头数据,为注册机提供搜索位置,改写即篡改非零
- 0x22345678,//头数据,为注册机提供搜索位置,改写即篡改非零
- 0x20231025,//多项式可以是随机数,例如今天是2023.10.25
- 0,//Flash基地址
- 0x0FD7,//HEX长度
- 0xF99741E0,//CRC32初值1,正向验证
- 0x0C38B4F3 //CRC32初值2,反向验证
- uint32_t CRC32Val(uint32_t input, uint32_t poly, uint32_t init, uint32_t xorout)
- {//菜农HotPower@163.com
- uint32_t ch;
- int i;
- input ^= init;
- if ((poly & 1) > 0)
- for (i = 0; i < 32; i++)
- ch = input & 0x80000000;
- input <<= 1;
- if (ch > 0)
- input ^= poly;
- else
- ch = input & 1;
- input >>= 1;
- if (ch > 0)
- input ^= poly | 0x80000000;
- if ((poly & 0x80000001) == 0)
- input ^= poly ^ 0x80000001;
- input ^= xorout;
- return input;
- uint32_t CRC32Valx(uint32_t output, uint32_t poly, uint32_t init, uint32_t xorout)
- int i;
- output ^= xorout;
- output ^= poly ^ 0x80000001;
- if ((output & 1) > 0)
- output ^= poly;
- output >>= 1;
- output |= 0x80000000;
- else
- output >>= 1;
- else
- if ((output & 0x80000000) > 0)
- output ^= poly;
- output <<= 1;
- output |= 1;
- else
- output <<= 1;
- output ^= init;
- return output;
- void SetCRC32Init(uint32_t* init1, uint32_t* init2)
- uint16_t len = (CRC32Array[5] - ((int)(&CRC32Array[6]) & 3)) / 4;
- uint32_t CRC32Init;
- uint32_t crc32;
- uint32_t crcpoly = CRC32Array[3];
- int pos1 = (int)(&CRC32Array[6] - (uint16_t)CRC32Array[4]) / 4;
- int pos2 = (int)(&CRC32Array[7] - (uint16_t)CRC32Array[4]) / 4;
- int i;
- unsigned long volatile code *Flash = (unsigned long volatile code *)((int)(&CRC32Array[6]) & 3);
- CRC32Init = 0;
- for(i = len - 1;i >= 0;i--)
- crc32 = Flash[(uint16_t)CRC32Array[4] + i];
- if(!(i == pos1 || i == pos2))
- CRC32Init = CRC32Valx(CRC32Init, crcpoly, crc32, 0);
- else
- *init1 = CRC32Init;
- CRC32Init = 0;
- for(i = 0;i < len;i++)
- if(!(i == pos2))
- else
- *init2 = CRC32Init;
- uint32_t GetCRC32Init12()
- uint32_t crc32;
- int i;
- CRC32Init = CRC32Array[6];
- CRC32Init = CRC32Val(crc32, crcpoly, CRC32Init, 0);
- CRC32Init ^= CRC32Array[7];
- if(!(i == pos2))
- return CRC32Init;
- uint32_t GetCRC32Init1()
- uint32_t crc32;
- int i;
- return CRC32Init;
- uint32_t GetCRC32Init2()
- uint32_t crc32;
- int i;
- CRC32Init = CRC32Array[7];
- if(!(i == pos2))
- return CRC32Init;
- void main(void)
- uint32_t init1 = 0;//填入CRC32Array[6]的CRC32初值1
- uint32_t init2;//填入CRC32Array[7]的CRC32初值2
- volatile uint32_t init12;
- #ifndef MONITOR51
- SCON = 0x50;
- TMOD |= 0x20;
- TH1 = 221;
- TR1 = 1;
- TI = 1;
- #endif
- SetCRC32Init(&init1, &init2);//结果填入CRC32初值1(第1次),CRC32初值2(第2次),需要编译运行两次!!!
- init12 = GetCRC32Init12();//被篡改非零!!!可以篡改CRC32Array[0],CRC32Array[1],CRC32Array[2]
- init1 = GetCRC32Init1();//被篡改非零!!!可以篡改CRC32Array[0],CRC32Array[1],CRC32Array[2]
- init2 = GetCRC32Init2();//被篡改非零!!!可以篡改CRC32Array[0],CRC32Array[1],CRC32Array[2]
- printf("init12 = 0x%08LX\n", init12);
- printf("init1 = 0x%08LX\n", init1);
- printf("init2 = 0x%08LX\n", init2);
- while (1) {
- printf ("Hello World\n"); /* Print "Hello World" */
