GD32为什么用PA2代替key按键功能不成功
1819|18
 楼主| kk93 发表于 2024-7-25 10:27 | 显示全部楼层 |阅读模式
配置PA4 ADC引脚,将PA2代替key功能,一脚接地一脚接PA2,想实现在另一key按键控制oled屏同时(使用了PA1),如果杜邦线连接了地与PA2,可以在oled屏幕上显示读取的ADC值程序如下 运行无误但是PA2连接时无法实现预期功能,PA1正常运行
请大佬解答~谢谢
#include "gd32f30x.h"
#include "systick.h"
#include <stdio.h>
#include "oled.h"
extern uint8_t IntFlag;//进入中断服务程序标志,在EXTI1_IRQHandler()函数置位
// 定义一个变量来跟踪当前显示的行
static uint8_t currentLine = 0;
// 定义一个数组来存储要显示的信息的索引或字符串指针
static const uint8_t chineseMessages[][2] = {
    {12, 0}, //
    {30, 1}, //
    {48, 2}, //
    {66, 3}, //
    {84, 4}, //
    {102, 5} //
static uint8_t *englishMessages[] = {
    "HUZHOU",
    "TEL:12345678"
uint16_t adc_value;
uint16_t Vol_Value;
float Vol_Value1;
void adc_config(void)
   /* reset ADC */
    adc_deinit(ADC1);
//    /* ADC mode config */
    adc_mode_config(ADC_MODE_FREE);
    /* ADC continous function enable */
    adc_special_function_config(ADC1, ADC_CONTINUOUS_MODE, ENABLE);
    /* ADC data alignment config */
    adc_data_alignment_config(ADC1, ADC_DATAALIGN_RIGHT);
      /* ADC resolusion 6B */
    // adc_resolution_config(ADC1, ADC_RESOLUTION_6B);
    /* ADC channel length config */
    adc_channel_length_config(ADC1, ADC_REGULAR_CHANNEL, 1);
    /* ADC regular channel config */
    adc_regular_channel_config(ADC1, 0, ADC_CHANNEL_4, ADC_SAMPLETIME_55POINT5);
    /* ADC trigger config */
     adc_external_trigger_source_config(ADC1, ADC_REGULAR_CHANNEL, ADC0_1_2_EXTTRIG_REGULAR_NONE);
     adc_external_trigger_config(ADC1, ADC_REGULAR_CHANNEL, ENABLE);
    /* enable ADC interface */
    adc_enable(ADC1);
    delay_1ms(1);
    /* ADC calibration and reset calibration */
    adc_calibration_enable(ADC1);
        //        adc_software_trigger_enable(ADC0,ADC_REGULAR_CHANNEL);
int main(void)
        rcu_ahb_clock_config(RCU_AHB_CKSYS_DIV1);//设置主频120M(#define __SYSTEM_CLOCK_120M_PLL_HXTAL           (uint32_t)(120000000),8M外部晶振  (#define HXTAL_VALUE    ((uint32_t)8000000))
        systick_config();//1ms systick
        rcu_periph_clock_enable(RCU_AF); //AF时钟使能
        delay_1ms(1000);//等待1000ms
        gpio_pin_remap_config(GPIO_SWJ_NONJTRST_REMAP, ENABLE);//下载口NJTRST引脚当做普通I/O口
        rcu_periph_clock_enable(RCU_GPIOB);//PB时钟使能
        gpio_init(GPIOB, GPIO_MODE_OUT_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_4);//PB4配置成输出
        //配置PA4 ADC引脚
         rcu_periph_clock_enable(RCU_GPIOA);
         gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
        /* enable ADC1 clock */
        rcu_periph_clock_enable(RCU_ADC1);
                /* config ADC clock */
        rcu_adc_clock_config(RCU_CKADC_CKAPB2_DIV8);
        //配置ADC
        adc_config();
        adc_software_trigger_enable(ADC1, ADC_REGULAR_CHANNEL);
        OLED_Init();//OLED初始化
        OLED_Clear();//OLED清屏
        gpio_init(GPIOA, GPIO_MODE_IPU, GPIO_OSPEED_50MHZ, GPIO_PIN_1);//PA1配置成上拉输入
        nvic_irq_enable(EXTI1_IRQn, 2U, 0U);//enable and set key EXTI interrupt to the lowest priority
        gpio_exti_source_select(GPIO_PORT_SOURCE_GPIOA, GPIO_PIN_SOURCE_1);//connect key EXTI line to key GPIO pin
        exti_init(EXTI_1, EXTI_INTERRUPT, EXTI_TRIG_FALLING);//下降沿中断
        exti_interrupt_flag_clear(EXTI_1);//清中断标志
        //PA2给ADC
        gpio_init(GPIOA, GPIO_MODE_IPU, GPIO_OSPEED_50MHZ, GPIO_PIN_2);//PA2配置成上拉输入
        nvic_irq_enable(EXTI2_IRQn, 2U, 0U);//enable and set key EXTI interrupt to the lowest priority
        gpio_exti_source_select(GPIO_PORT_SOURCE_GPIOA, GPIO_PIN_SOURCE_2);//connect key EXTI line to key GPIO pin
        exti_init(EXTI_2, EXTI_INTERRUPT, EXTI_TRIG_FALLING);//下降沿中断
        exti_interrupt_flag_clear(EXTI_2);//清中断标志
    while (1)
                if (gpio_input_bit_get(GPIOA, GPIO_PIN_2) == RESET && IntFlag == 0x55)   //ADC显示电压 需要换个接口
                        adc_flag_clear(ADC1,ADC_FLAG_EOC);//清ADC结束标志
                        while(SET != adc_flag_get(ADC1,ADC_FLAG_EOC))
                                {//判断是否结束
                                        adc_value = ADC_RDATA(ADC1);//读取ADC寄存器值
                                        Vol_Value=adc_value*3300/4095/1000;//寄存器值转换成电压值
                                        //Vol_Value1=330;
                                        OLED_ShowNum(5,2,Vol_Value1,4,32);
                                        delay_1ms(1000);
                                }//等待5秒
        if (gpio_input_bit_get(GPIOA, GPIO_PIN_1) == RESET && IntFlag == 0x55)   //信息显示
            // 清除中断标志(重要,防止重复触发)
            IntFlag = 0; // 假设这是一个合适的清零操作
            OLED_Clear();
            gpio_bit_set(GPIOB, GPIO_PIN_4);
            // 根据currentLine的值显示相应的信息
            if (currentLine < sizeof(chineseMessages) / sizeof(chineseMessages[0]))
                                OLED_ShowCHinese(chineseMessages[currentLine][0], 0, chineseMessages[currentLine][1]);
            else if (currentLine >= sizeof(chineseMessages) / sizeof(chineseMessages[0]) &&
                     currentLine < sizeof(chineseMessages) / sizeof(chineseMessages[0]) + sizeof(englishMessages) / sizeof(englishMessages[0]))
                if((currentLine - sizeof(chineseMessages) / sizeof(chineseMessages[0]))==0)
                                        OLED_ShowCHinese(12,0,0);//显示中文
                                        OLED_ShowCHinese(30,0,1);//显示中文
                                        OLED_ShowCHinese(48,0,2);//显示中文
                                        OLED_ShowCHinese(66,0,3);//显示中文
                                        OLED_ShowCHinese(84,0,4);//显示中文
                                        OLED_ShowCHinese(102,0,5);//显示中文
                                        OLED_ShowString(21, 3, englishMessages[currentLine - sizeof(chineseMessages) / sizeof(chineseMessages[0])]);
                                if((currentLine - sizeof(chineseMessages) / sizeof(chineseMessages[0]))==1)
                                        OLED_ShowCHinese(12,0,0);//显示中文(浙)
                                        OLED_ShowCHinese(30,0,1);//显示中文(江)
                                        OLED_ShowCHinese(48,0,2);//显示中文(力)
                                        OLED_ShowCHinese(66,0,3);//显示中文(控)
                                        OLED_ShowCHinese(84,0,4);//显示中文(科)
                                        OLED_ShowCHinese(102,0,5);//显示中文(技)
                                        OLED_ShowString(21,3,(u8 *)"HUZHOU*ANJI");//显示字符 这里都是先列后行
                                        OLED_ShowString(16, 6, englishMessages[currentLine - sizeof(chineseMessages) / sizeof(chineseMessages[0])]);
            delay_1ms(100); // 假设这里延迟1秒,以便观察显示结果
            gpio_bit_reset(GPIOB, GPIO_PIN_4);
            // 更新currentLine以显示下一行(如果有的话)
            currentLine = (currentLine + 1) % (sizeof(chineseMessages) / sizeof(chineseMessages[0]) + sizeof(englishMessages) / sizeof(englishMessages[0]));
shenxiaolin 发表于 2024-7-29 22:15 | 显示全部楼层
感谢分享
小小蚂蚁举千斤 发表于 2024-7-31 22:34 | 显示全部楼层
这个得需要外部硬件实现的
gra22ce 发表于 2024-8-19 11:05 | 显示全部楼层
你想PA2按下之后读取ADC操作?看看你的PA2的配置呗
eleg34ance 发表于 2024-8-19 12:10 | 显示全部楼层
一般情况是你IO配置不对或者复用不对导致的
suiziq 发表于 2024-8-19 14:23 | 显示全部楼层
你说PA1正常是啥意思,是PA1可以按键触发,PA2不可以?
pe66ak 发表于 2024-8-19 16:27 | 显示全部楼层
我建议你仿真看看,你的IO配置和你的程序逻辑
wamed 发表于 2024-8-19 17:02 | 显示全部楼层
我看你PA1和PA2的函数都一样啊,不应该1好使2不好使啊
teaccch 发表于 2024-8-19 18:34 | 显示全部楼层
你看看PA2的优先级呢?设置高点?
elephant00 发表于 2024-8-19 18:34 | 显示全部楼层
可能是引脚复用与配置问题
jcky001 发表于 2024-8-19 18:35 | 显示全部楼层
如果PA2引脚没有正确配置内部上拉或下拉电阻,或者配置的上拉/下拉电阻强度不足以稳定电平,那么按键输入可能会不稳定或无法被正确识别。
两只袜子 发表于 2024-8-19 19:26 | 显示全部楼层
cr315 发表于 2024-8-19 20:23 | 显示全部楼层
中断或轮询逻辑存在错误
duo点 发表于 2024-8-19 21:26 | 显示全部楼层
消抖处理不当或未实现
onlycook 发表于 2024-8-19 22:26 | 显示全部楼层
检查PA2引脚与按键硬件之间的连接是否正确
星星点点didi 发表于 2024-8-20 08:25 | 显示全部楼层
你不用外部触发的方式呗,用定时获取IO状态的方式
nqty 发表于 2024-8-20 09:12 | 显示全部楼层
是不是你的PA2被用在其他地方了啊
canfeil 发表于 2024-8-20 11:06 | 显示全部楼层
看你截出来的程序来说,应该是没啥问题啊,我觉得
nuan11nuan 发表于 2024-8-20 12:31 | 显示全部楼层
这个不好说,那你换个IO试试?主要不知道你硬件咋设计的,所以不好说啊
