GD32F470IK CAN通信配置问题(过滤器)
3133|10
 楼主| sayato 发表于 2024-9-11 12:49 | 显示全部楼层 |阅读模式
采用GD32F470IK,该芯片有两个CAN,CAN0,CAN1,问题:仅在CAN0被配置的情况下CAN1配置后才能接收到收据,否则CAN1仅能发出数据,
查阅了相关资料个人感觉是filter.number设置有关系,因为该芯片只有CAN0才能操作CAN_FCTL寄存器,但是这个操作都是官方在如下函数写死的,即使配置CAN1的时候应当也能操作这个寄存器啊,实际为什么不行呢?
void can_filter_init(can_filter_parameter_struct *can_filter_parameter_init)
    uint32_t val = 0U;
    val = ((uint32_t)1) << (can_filter_parameter_init->filter_number);
    /* filter lock disable */
    CAN_FCTL(CAN0) |= CAN_FCTL_FLD;
    /* disable filter */
    CAN_FW(CAN0) &= ~(uint32_t)val;
我的CAN 配置如下:
void CAN0_Init(void)
    can_parameter_struct can_parameter;
    can_filter_parameter_struct can_filter;
    /* initialize CAN structures */
    can_struct_para_init(CAN_INIT_STRUCT, &can_parameter);
    can_struct_para_init(CAN_FILTER_STRUCT, &can_filter);
    /* initialize CAN register */
                /* enable CAN clock */
    rcu_periph_clock_enable(RCU_CAN0);
    rcu_periph_clock_enable(RCU_GPIOB);
    can_deinit(CAN0);
    /* configure CAN0 RX */
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_8);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_8);
    gpio_af_set(GPIOB, GPIO_AF_9, GPIO_PIN_8);
        /* configure CAN0 TX */
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_9);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_9);
    gpio_af_set(GPIOB, GPIO_AF_9, GPIO_PIN_9);
    /* initialize CAN */
    can_parameter.time_triggered = DISABLE;
    can_parameter.auto_bus_off_recovery = ENABLE;
    can_parameter.auto_wake_up = DISABLE;
    can_parameter.auto_retrans = ENABLE;
    can_parameter.rec_fifo_overwrite = DISABLE;
    can_parameter.trans_fifo_order = DISABLE;
    can_parameter.working_mode = CAN_NORMAL_MODE;
    can_parameter.resync_jump_width = CAN_BT_SJW_1TQ;
    can_parameter.time_segment_1 = CAN_BT_BS1_16TQ;
    can_parameter.time_segment_2 = CAN_BT_BS2_3TQ;
        /* baudrate 100kbps ,APB1:60000000,*/
    can_parameter.prescaler = 30;
                can_init(CAN0, &can_parameter);
    /* initialize filter */
    /* CAN0 filter number */
    can_filter.filter_number = 0;
    can_filter.filter_mode = CAN_FILTERMODE_MASK;
    can_filter.filter_bits = CAN_FILTERBITS_32BIT;
    can_filter.filter_list_high = 0x0000;
    can_filter.filter_list_low = 0x0000;
    can_filter.filter_mask_high = 0x0000;
    can_filter.filter_mask_low = 0x0000;
    can_filter.filter_fifo_number = CAN_FIFO0;
    can_filter.filter_enable = ENABLE;
    can_filter_init(&can_filter);
                can_interrupt_enable(CAN0, CAN_INTEN_RFNEIE0);
                nvic_irq_enable(CAN0_RX0_IRQn, 0, 0);
void CAN1_Init(void)
    rcu_periph_clock_enable(RCU_CAN1);
    can_deinit(CAN1);
                /* configure CAN1 GPIO */
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_5);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_5);
    gpio_af_set(GPIOB, GPIO_AF_9, GPIO_PIN_5);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_6);
    gpio_af_set(GPIOB, GPIO_AF_9, GPIO_PIN_6);
                can_init(CAN1, &can_parameter);
    can_filter.filter_number = 15;
                can_interrupt_enable(CAN1, CAN_INTEN_RFNEIE0);
                nvic_irq_enable(CAN1_RX0_IRQn, 0, 0);
 楼主| sayato 发表于 2024-9-11 12:50 | 显示全部楼层
想请教  为什么CAN1能够正常收发,必须要配置can1 否则就是不可以???
jcky001 发表于 2024-9-12 15:55 | 显示全部楼层
修改can_filter_init函数
cr315 发表于 2024-9-12 17:45 | 显示全部楼层
检查是否有任何特殊的硬件限制或要求,特别是关于如何配置CAN1的过滤器。
两只袜子 发表于 2024-9-12 17:45 | 显示全部楼层
检查硬件手册
jcky001 发表于 2024-9-12 20:12 | 显示全部楼层
尽量使用GD32提供的库函数或HAL(硬件抽象层)来配置CAN模块
 楼主| sayato 发表于 2024-9-13 16:36 | 显示全部楼层
修改can_filter_init函数
老哥 你没跟我开玩笑吧,首先作为标准库,没有致命问题,一般不会去动他,如果你更新了驱动库,难道还要去改吗,万一忘记改怎么办,目前 我只想搞清楚为什么只有can0初始化后为什么CAN1才能工作,can_filter 只是我怀疑的一个点,也许我的问题就不是这个点引起的
 楼主| sayato 发表于 2024-9-13 16:38 | 显示全部楼层
项目就是用的标准库,好多程序都是复用一些驱动的 不太想去换HAL库啊,另外我这个函数都是标准库的内容,不是自己写的
szt1993 发表于 2024-9-24 14:11 | 显示全部楼层
CAN0与CAN1肯定是不一样的
王派oo 发表于 2024-9-30 13:30 来自手机 | 显示全部楼层
