我用的ise10.1 写了一个很简单的程序 老实现不了 错误提示如下:
ERROR:Par:332 - The evaluation period for this evaluation software has expired. As stated in the guidelines of the
Evaluation Agreement, which was shipped to you along with the Evaluation CDs, this software will no longer operate.
We are eager to assist you as you conclude your evaluation of the Xilinx solution. Your local Field Applications
Engineer or salesperson is available to answer any questions or to assist you in the purchase of an annual software
license. You may also contact Xilinx directly at eval@xilinx.com
Thank you for evaluating the Xilinx solution. We appreciate your interest in Xilinx and we look forward to earning
your confidence and your business.
Process "Place & Route" failed
下面是verilog代码
module good(
cout,sum,ina,inb,cin
output[3:0] sum;
output cout;
input[3:0] ina,inb;
input cin;
assign{cout,sum}=ina+inb+cin;
endmodule
我还试过其它的代码 都是实现的时候提示这个错误 不知道错在哪里了 请各位高人指点下,小弟万分感激。 |
