- #include "platform.h"
- #include "SEGGER_RTT.h"
- volatile uint32_t PLATFORM_DelayTick = 0;
- void PLATFORM_InitSysTick(void)
- RCC_ClocksTypeDef RCC_Clocks;
- RCC_GetClocksFreq(&RCC_Clocks);
- if (SysTick_Config(RCC_Clocks.HCLK_Frequency / 1000))
- while (1)
- NVIC_SetPriority(SysTick_IRQn, 0x0);
- void PLATFORM_ConfigDelay(void)
- NVIC_InitTypeDef NVIC_InitStruct;
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStruct;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);
- TIM_TimeBaseStructInit(&TIM_TimeBaseStruct);
- TIM_TimeBaseStruct.TIM_Prescaler = (TIM_GetTIMxClock(TIM6) / 100000 - 1);
- TIM_TimeBaseStruct.TIM_CounterMode = TIM_CounterMode_Up;
- TIM_TimeBaseStruct.TIM_Period = (100 - 1);
- TIM_TimeBaseStruct.TIM_ClockDivision = TIM_CKD_Div1;
- TIM_TimeBaseStruct.TIM_RepetitionCounter = 0;
- TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStruct);
- TIM_ITConfig(TIM6, TIM_IT_Update, ENABLE);
- NVIC_InitStruct.NVIC_IRQChannel = TIM6_IRQn;
- NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStruct.NVIC_IRQChannelSubPriority = 1;
- NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStruct);
- TIM_Cmd(TIM6, ENABLE);
- void PLATFORM_DelayMs(uint32_t Tick)
- PLATFORM_DelayTick = Tick;
- while (PLATFORM_DelayTick)
- void PLATFORM_InitConsole(void)
- SEGGER_RTT_ConfigUpBuffer(0, "RTTUP", NULL, 0, SEGGER_RTT_MODE_NO_BLOCK_SKIP);
- int fputc(int ch, FILE *f)
- SEGGER_RTT_PutCharSkip(0, (char)ch);
- return (ch);
- void PLATFORM_PrintClocks(void)
- printf("\r\nBOARD : Mini-F5333");
- printf("\r\nMCU : MM32F5333D7P");
- printf("\r\n");
- switch (RCC->CFGR & RCC_CFGR_SWS_Msk)
- case 0x00:
- printf("\r\nHSI used as system clock source");
- break;
- case 0x04:
- printf("\r\nHSE used as system clock source");
- break;
- case 0x08:
- if (RCC->PLL1CFGR & RCC_PLL1CFGR_PLL1SRC_Msk)
- printf("\r\nPLL1 (clocked by HSE) used as system clock source");
- else
- printf("\r\nPLL1 (clocked by HSI) used as system clock source");
- break;
- case 0x0C:
- printf("\r\nLSI used as system clock source");
- break;
- default:
- break;
- printf("\r\n");
- printf("\r\nSYSCLK Frequency : %7.3f MHz", (double)RCC_Clocks.SYSCLK_Frequency / (double)1000000.0);
- printf("\r\nHCLK Frequency : %7.3f MHz", (double)RCC_Clocks.HCLK_Frequency / (double)1000000.0);
- printf("\r\nPCLK1 Frequency : %7.3f MHz", (double)RCC_Clocks.PCLK1_Frequency / (double)1000000.0);
- printf("\r\nPCLK2 Frequency : %7.3f MHz", (double)RCC_Clocks.PCLK2_Frequency / (double)1000000.0);
- printf("\r\n");
- void PLATFORM_Init(void)
- PLATFORM_InitSysTick();
- PLATFORM_ConfigDelay();
- PLATFORM_InitConsole();
- PLATFORM_PrintClocks();
- void TIM6_IRQHandler(void)
- if (RESET != TIM_GetITStatus(TIM6, TIM_IT_Update))
- if (PLATFORM_DelayTick)
- PLATFORM_DelayTick--;
- TIM_ClearITPendingBit(TIM6, TIM_IT_Update);
6.2.LED驱动
- #include "bsp_led.h"
- void bsp_LedInit(void)
- GPIO_InitTypeDef GPIO_InitStruct;
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
- GPIO_StructInit(&GPIO_InitStruct);
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_10 ;
- GPIO_InitStruct.GPIO_Speed = GPIO_Speed_High;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOB, &GPIO_InitStruct);
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_6;
- GPIO_Init(GPIOC, &GPIO_InitStruct);
- GPIO_WriteBit(GPIOB, GPIO_Pin_11, Bit_SET);
- GPIO_WriteBit(GPIOB, GPIO_Pin_10, Bit_SET);
- GPIO_WriteBit(GPIOC, GPIO_Pin_7, Bit_SET);
- GPIO_WriteBit(GPIOC, GPIO_Pin_6, Bit_SET);
- void bsp_LedToggle(uint8_t Index)
- switch (Index)
- case 1:
- if (GPIO_ReadOutputDataBit(GPIOB, GPIO_Pin_11) == Bit_RESET)
- else
- GPIO_WriteBit(GPIOB, GPIO_Pin_11, Bit_RESET);
- break;
- case 2:
- if (GPIO_ReadOutputDataBit(GPIOB, GPIO_Pin_10) == Bit_RESET)
- else
- GPIO_WriteBit(GPIOB, GPIO_Pin_10, Bit_RESET);
- break;
- case 3:
- if (GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_7) == Bit_RESET)
- else
- GPIO_WriteBit(GPIOC, GPIO_Pin_7, Bit_RESET);
- break;
- case 4:
- if (GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_6) == Bit_RESET)
- else
- GPIO_WriteBit(GPIOC, GPIO_Pin_6, Bit_RESET);
- break;
- default:
- break;
6.3.KEY驱动
- #include "bsp_key.h"
- void bsp_KeyInit(void)
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_4;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IPD;
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_5;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IPU;
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2;
- uint8_t bsp_KeyReadPinLevel(uint8_t Index)
- uint8_t PinLevel = 0;
- switch (Index)
- case 1:
- PinLevel = GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_4);
- break;
- case 2:
- PinLevel = GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_5);
- break;
- case 3:
- PinLevel = GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_1);
- break;
- case 4:
- PinLevel = GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_2);
- break;
- default:
- break;
- return (PinLevel);
6.4.按键应用
- #include "key.h"
- #include "multi_button.h"
- struct Button K1;
- struct Button K2;
- struct Button K3;
- struct Button K4;
- volatile uint8_t KeyRegisterFlag = 0;
- volatile uint8_t KeyHttpPostFlag = 0;
- void KEY_PressUpHandler(void *btn)
- struct Button *handle = (struct Button *)btn;
- switch (handle->button_id)
- case 1:
- printf("\r\nK1");
- break;
- case 2:
- printf("\r\nK2");
- break;
- case 3:
- printf("\r\nK3");
- break;
- case 4:
- printf("\r\nK4"); KeyHttpPostFlag = 1;
- break;
- default:
- break;
- void KEY_Init(void)
- button_init(&K1, bsp_KeyReadPinLevel, Bit_SET, 1);
- button_init(&K2, bsp_KeyReadPinLevel, Bit_RESET, 2);
- button_init(&K3, bsp_KeyReadPinLevel, Bit_RESET, 3);
- button_init(&K4, bsp_KeyReadPinLevel, Bit_RESET, 4);
- button_attach(&K1, PRESS_UP, KEY_PressUpHandler);
- button_attach(&K2, PRESS_UP, KEY_PressUpHandler);
- button_attach(&K3, PRESS_UP, KEY_PressUpHandler);
- button_attach(&K4, PRESS_UP, KEY_PressUpHandler);
- button_start(&K1);
- button_start(&K2);
- button_start(&K3);
- button_start(&K4);
- KeyRegisterFlag = 1;
- void SysTick_Handler(void)
- if (KeyRegisterFlag)
- button_ticks();
6.5.Air724驱动
- #include "bsp_air724.h"
- uint8_t Air724_RxBuffer[2048];
- uint16_t Air724_RxLength = 0;
- char deepseek_Buffer[2048];
- void bsp_Air724InitUART(void)
- UART_InitTypeDef UART_InitStruct;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE);
- UART_StructInit(&UART_InitStruct);
- UART_InitStruct.BaudRate = 115200;
- UART_InitStruct.WordLength = UART_WordLength_8b;
- UART_InitStruct.StopBits = UART_StopBits_1;
- UART_InitStruct.Parity = UART_Parity_No;
- UART_InitStruct.HWFlowControl = UART_HWFlowControl_None;
- UART_InitStruct.Mode = UART_Mode_Rx | UART_Mode_Tx;
- UART_Init(UART4, &UART_InitStruct);
- GPIO_PinAFConfig(GPIOC, GPIO_PinSource0, GPIO_AF_8);
- GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_8);
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_1;
- UART_ITConfig(UART4, UART_IT_RX, ENABLE);
- NVIC_InitStruct.NVIC_IRQChannel = UART4_IRQn;
- UART_Cmd(UART4, ENABLE);
- void bsp_Air724RxIrqHandler(uint8_t Data)
- printf("%c", Data);
- Air724_RxBuffer[Air724_RxLength] = Data;
- Air724_RxLength += 1;
- Air724_RxLength %= 2048;
- void bsp_Air724InitGPIO(void)
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOI, ENABLE);
- GPIO_Init(GPIOI, &GPIO_InitStruct);
- GPIO_WriteBit(GPIOI, GPIO_Pin_0, Bit_SET);
- void bsp_Air724Reset(void)
- PLATFORM_DelayMs(100);
- GPIO_WriteBit(GPIOI, GPIO_Pin_0, Bit_RESET);
- void bsp_Air724ClearRxBuffer(void)
- Air724_RxLength = 0;
- for (uint16_t i = 0; i < 2048; i++)
- Air724_RxBuffer[i] = 0;
- void bsp_Air724Init(void)
- bsp_Air724InitUART();
- bsp_Air724InitGPIO();
- bsp_Air724ClearRxBuffer();
- void bsp_Air724SendData(uint8_t Data)
- UART_SendData(UART4, Data);
- while (RESET == UART_GetFlagStatus(UART4, UART_FLAG_TXC))
- uint32_t bsp_Air724SendCommandBlocking(char *Command, char *Response, uint32_t Timeout)
- if (Command != NULL)
- while (*Command != '\0')
- bsp_Air724SendData(*Command++);
- bsp_Air724SendData(0x0D);
- bsp_Air724SendData(0x0A);
- if (Timeout != 0)
- while (Timeout--)
- if (strstr((char *)Air724_RxBuffer, Response) != NULL)
- return (Timeout);
- PLATFORM_DelayMs(1);
- return (0);
- void bsp_Air724InputDataNonBlocking(char *Data)
- if (Data != NULL)
- while (*Data != '\0')
- bsp_Air724SendData(*Data++);
- bsp_Air724SendData(0x1A);
6.6.HTTP初始化
- void HTTP_Init(void)
- bsp_Air724Reset();
- bsp_Air724SendCommandBlocking(NULL, "RDY", 10000);
- bsp_Air724SendCommandBlocking(NULL, "+NITZ", 10000);
- PLATFORM_DelayMs(500);
- bsp_Air724SendCommandBlocking("AT", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+CPIN?", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+CGATT?", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+SAPBR=3,1,"CONTYPE","GPRS"", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+SAPBR=3,1,"APN",""", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+SAPBR=1,1", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+SAPBR=2,1", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+CGNSPWR=1", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+CSQ", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+CGNSAID=31,1,1,1", "OK", 10000);
6.7.HTTP与DeepSeek交互
- char POST_DATA[] =
- "model": "deepseek-chat",\
- "messages": [{"role": "user", "content": "who are you?"}],\
- "stream": false\
- void HTTP_Post(void)
- char Command[200];
- bsp_Air724SendCommandBlocking("AT+HTTPINIT", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+HTTPSSL=1", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+HTTPPARA="CID",1", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+HTTPPARA="URL","https://api.deepseek.com/chat/completions"", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+HTTPPARA="CONTENT","application/json"", "OK", 10000);
- bsp_Air724SendCommandBlocking("AT+HTTPPARA="USERDATA","Authorization:Bearer API key"", "OK", 10000);
- memset(Command, 0, sizeof(Command));
- sprintf(Command, "AT+HTTPDATA=%d,10000", strlen(POST_DATA));
- bsp_Air724SendCommandBlocking(Command, "DOWNLOAD", 30000);
- printf("\r\n%s", POST_DATA);
- bsp_Air724InputDataNonBlocking(POST_DATA);
- bsp_Air724SendCommandBlocking("AT+HTTPACTION=1", "OK", 30000);
- bsp_Air724SendCommandBlocking(NULL, "+HTTPACTION: 1,200,", 30000);
- bsp_Air724SendCommandBlocking("AT+HTTPREAD", "OK", 30000);
- bsp_Air724RxHandler();
- bsp_Air724SendCommandBlocking("AT+HTTPTERM", "OK", 10000);
6.8.DeepSeek数据处理
- #include "cJSON.h"
- void bsp_Air724RxHandler(void)
- uint16_t Count = 0;
- uint16_t Group = 0;
- memset(deepseek_Buffer, 0, sizeof(deepseek_Buffer));
- for (uint16_t i = 0; i < Air724_RxLength; i++)
- if (Air724_RxBuffer[i] == '{')
- Group++;
- if (Group)
- deepseek_Buffer[Count++] = Air724_RxBuffer[i];
- if (Air724_RxBuffer[i] == '}')
- if(Group) Group--;
- printf("\r\n--------------------------------------------------------------------------------");
- cJSON *cjson = cJSON_Parse(deepseek_Buffer);
- char *json_data = cJSON_Print(cjson);
- if (cjson == NULL)
- printf("\r\ncjson error!!!");
- else
- printf("\r\n%s", json_data);
- printf("\r\n");
7.运行结果
MCU向DeepSeek发送了"who are you?"的提问,如下图,DeepSeek进行了回答“I’m an AI language model created by OpenAI……”
8.附件
软件工程代码:
Mini-F5333_Air724_21ic.zip
(502.76 KB, 下载次数: 39)
