中颖88f516,类eeprom的读写,已验证
3485|4
 楼主| 孤独泪 发表于 2012-9-28 16:44 | 显示全部楼层 |阅读模式
#define  FLASHDATA_PAGE0    0x0000
#define  FLASHDATA_PAGE1    0x0100
#define  FLASHDATA_PAGE2    0x0200
#define  FLASHDATA_PAGE3    0x0300
#define  CONFIGADDRESS      FLASHDATA_PAGE0  //eeprom 0页地址
#define  CONFIGCOPYADDRESS  FLASHDATA_PAGE1  //eeprom 1页地址
////IB_CON1的定义
#define  ERASEPAGE   0xE6
#define  WRITEPAGE   0x6E
static unsigned char ssp_flag;
//////擦除指定地址t_addr扇区的类容
void SspErase(unsigned int t_addr)
EA = 0;
XPAGE = (t_addr>>8) & 0x07;
FLASHCON=1;
if (ssp_flag==0x55)
  IB_CON1 = ERASEPAGE;
  IB_CON2 = 0x05;
  IB_CON3 = 0x0A;
  IB_CON4 = 0x09;
  IB_CON5 = 0x06;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
else
  IB_CON2 = 0x00;
ssp_flag = 0;
FLASHCON=0;
XPAGE=0;
EA = 1;
void SspWrite(unsigned int addr,unsigned char dat)
EA=0;
IB_DATA = dat;
IB_OFFSET = addr&0xff;
XPAGE = ((addr>>8) & 7);
FLASHCON=1;
if(ssp_flag==0x55)
  IB_CON1 = 0x6E;
  IB_CON2 = 0x05;
  IB_CON3 = 0x0A;
  IB_CON4 = 0x09;
  IB_CON5 = 0x06;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
else
  IB_CON2=0;
ssp_flag=0;
FLASHCON=0;
XPAGE=0;
EA = CY;
unsigned char SspRead(unsigned int addr)
unsigned char temp;
EA = 0;
FLASHCON=1;
temp=*(unsigned char code *)(addr);
FLASHCON=0;
EA = 1;
return(temp);
///////写num个字节的数据到扇区t_addr
void WriteEeprom(unsigned int t_addr,unsigned char num,unsigned char *ptr)
unsigned char loop;
ssp_flag = 0x55;
SspErase(t_addr);
for (loop=0; loop<num; loop++)
  ssp_flag = 0x55;
  SspWrite(t_addr, *ptr);
  t_addr++;
  ptr++;
///////从扇区地址t_addr内读出数据送缓冲区
void ReadEeprom(unsigned int t_addr,unsigned char num,unsigned char *ptr)
unsigned int loop;
  *ptr = SspRead(t_addr);
  ptr++;
  t_addr++;
////返回1表示当前存储的数据出现错误,否则返回零
unsigned char CheckEeprom(unsigned int t_addr, unsigned int num, unsigned char xdata *ptr)
unsigned char da;
unsigned char res = 0;
unsigned int loop;
  da = SspRead(t_addr);
  if (da !=  *ptr)
   res = 1;
   break;
  t_addr++;
  ptr++;
return(res);
void WriteConfig(void)
unsigned char i;
/// unsigned char chksum;
unsigned char xdata *ptr;
config_data.flag_frist=0x55;
config_data.checksum = 0;
ptr = (unsigned char xdata*)&config_data;
for (i=0; i<(sizeof(config_data)-1); i++)
  config_data.checksum += *(ptr+i);
do
{////写原始页的数据
  WriteEeprom(CONFIGADDRESS, sizeof(config_data), (unsigned char xdata*)&config_data);
}while(CheckEeprom(CONFIGADDRESS, sizeof(config_data), (unsigned char xdata*)&config_data));
do
{///写备份页的数据
  WriteEeprom(CONFIGCOPYADDRESS, sizeof(config_data), (unsigned char xdata*)&config_data);
}while(CheckEeprom(CONFIGCOPYADDRESS, sizeof(config_data), (unsigned char xdata*)&config_data));
//返回1表示读取的配置不正确
//返回0表示读取的配置正确
unsigned char ReadConfig(void)
unsigned int i;
ReadEeprom(CONFIGADDRESS, sizeof(config_data), (unsigned char xdata*)&config_data);
chksum = 0;
ptr = (unsigned char xdata *)&config_data;
  chksum += *(ptr+i);
if ((config_data.flag_frist==0x55) && (chksum = config_data.checksum))
{/////数据正确
  if (CheckEeprom(CONFIGCOPYADDRESS, sizeof(config_data), (unsigned char xdata*)&config_data))
  {///检测到备份页的数据也不正确
  return(0);
////原始页不正确,继续判断备份页
ReadEeprom(CONFIGCOPYADDRESS, sizeof(config_data), (unsigned char xdata*)&config_data);
chksum = 0;
for (i=0; i<sizeof(config_data); i++)
  chksum += *(ptr+i);
{/////数据正确
  return(0);
return(1);
fenglimingemail 发表于 2012-9-28 18:07 | 显示全部楼层
cenjb1985211 发表于 2020-2-16 16:37 | 显示全部楼层
这个 config_data结构体怎么做啊,谢谢啊?
余三水 发表于 2020-2-25 11:58 | 显示全部楼层
应该是在头文件中定义的,作者没有上传。应该是几个操作flash的参数。
alexzhou88 发表于 2020-3-16 17:10 | 显示全部楼层
谢谢!
个人签名:高精度天平方案研究,称重系统开发,
97
