Libero IDE v9.1 使用中的问题,希望高手给予帮助啊!
5333|3
 楼主| mpxkali 发表于 2012-11-24 17:28 | 显示全部楼层 |阅读模式
Designer编译时出错信息,求解答!
Error: couldn't read file "C:\Users\天空\AppData\Local\Temp\pra06104-5.tmp": no such file or directory
Error: Can't open file: C:/Users/天空/AppData/Local/Temp/sda02604-3.tmp
Error: SDC Import: 1 error(s) detected in the file. All constraints have been ignored.
         In order for the SDC constraints to be used, please make sure to fix the error(s) and re-import the SDC file
Designer设计编译时的报错说明,谁能帮忙解决一下!
real_pumpkin 发表于 2012-12-22 15:57 | 显示全部楼层
硬盘空间不够啦?
zbhbyc 发表于 2012-12-27 12:45 | 显示全部楼层
路径中不能用中文
