【活动贴】捡起基础之特殊I/O
1322|2
 楼主| LMQQ 发表于 2013-2-13 23:06 | 显示全部楼层 |阅读模式
I/O, ce, ic, ev, pi
cyclone IV device handbook.pdf有比较详细的说明。
conf_done当device被配置文件后,为高电平
nconfig 程序正常运行为高电平
FPGA里面有一个internal oscillator for initialization,cyclone IV E里面是40M
CLKUSR
during POR(power up reset),the device resets,hold nstatus and conf_done low.
while nconfig  low,the device is in reset.you can begin reconfiguration by pulling nconfig pin low
when nconfig goes high,the device exits reset and release the open-drain nstatus pin,which is then pulled high by an external 10k pull-up resister
after nstatus is released,the device is ready to receive configuration data and the configuration stage starts.
cofiguration data is latched into cyclone iv device at each DCLK cycle
DATA0,DCLK , nCSO , ASDO连接EPCSX
the nCSO pin function as FLASH_nCE pin in AP mode,the ASDO pin functions as the DATA[1] pin in AP and FPP modes.
the nCEO is left unconnected or used as a user I/O pin when it does not feed nCE pin of another device.
JTAG下载口TDI , TDO , TMS , TCK
当使用JTAG,确保nCE是低电平
GoldSunMonkey 发表于 2013-2-13 23:30 | 显示全部楼层
感谢支持啊
星星之火红 发表于 2013-2-14 22:21 | 显示全部楼层
感谢支持啊
不错啊
