STM32 问题 求解决。。。
2215|4
 楼主| a111204508_c 发表于 2013-5-14 13:26 | 显示全部楼层 |阅读模式
u8 SPI_FLASH_SendByte(u8 byte)
  /* Loop while DR register in not emplty */
  while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
  /* Send byte through the SPI2 peripheral */
  SPI_I2S_SendData(SPI1, byte);
  /* Wait to receive a byte */
   while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
  /* Return the byte read from the SPI bus */
  return SPI_I2S_ReceiveData(SPI1);
程序一直卡在 while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
求指教!
swustlx86 发表于 2013-5-15 09:04 | 显示全部楼层
个人认为先检查下硬件   不知道对否
subo19920716 发表于 2013-5-16 10:43 | 显示全部楼层
我怀疑你没有初始化SPI,以及SPI的时钟
 楼主| a111204508_c 发表于 2013-5-16 16:12 | 显示全部楼层
SPI_InitTypeDef  SPI_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB , ENABLE);
        /* Configure SPI1 pins: SCK, MISO and MOSI */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        /* Configure I/O for Flash Chip select (NSS)*/
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        /* Configure I/O for PC6,PC7,GD0,GD2  */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7| GPIO_Pin_6;
        //GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
        /* Deselect the FLASH: Chip Select high */
        //SPI_FLASH_CS_HIGH();
        /* Enable SPI1 and GPIO clocks */
        RCC_APB1PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
        /* SPI1 configuration */
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;//SPI_Direction_2Lines_RxOnly;//SPI_Direction_2Lines_FullDuplex;
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
        SPI_InitStructure.SPI_CRCPolynomial = 7;
        SPI_Init(SPI1, &SPI_InitStructure);
        /* Enable SPI1  */
        SPI_Cmd(SPI1, ENABLE);
个人认为先检查下硬件   不知道对否
        /* Enable SPI1  */
