关于Cadence IC5141
3228|4
 楼主| song_yong 发表于 2008-7-22 10:22 | 显示全部楼层 |阅读模式
本人在Solaris9系统中,将IC5033更新到IC5141usr1,结果无法进行仿真,<br />出错提示如下:<br /><br />o&nbsp;generate&nbsp;netlist...<br />o&nbsp;Loading&nbsp;spectreinl.cxt&nbsp;<br />o&nbsp;Loading&nbsp;seCore.cxt&nbsp;<br />o&nbsp;Begin&nbsp;Incremental&nbsp;Netlisting&nbsp;Jul&nbsp;22&nbsp;09:46:26&nbsp;2008<br />o&nbsp;End&nbsp;netlisting&nbsp;Jul&nbsp;22&nbsp;09:46:26&nbsp;2008<br />o&nbsp;<br />o&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;The&nbsp;netlist&nbsp;is&nbsp;up&nbsp;to&nbsp;date.<br />o&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Time&nbsp;taken&nbsp;to&nbsp;compare&nbsp;the&nbsp;design&nbsp;with&nbsp;netlist:&nbsp;&nbsp;&nbsp;1.0s<br />o&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;...successful.<br />o&nbsp;compose&nbsp;simulator&nbsp;input&nbsp;file...<br />o&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;...successful.<br />o&nbsp;start&nbsp;simulator&nbsp;if&nbsp;needed...<br />o&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;...successful.<br />
&nbsp;t<br />o&nbsp;Problems&nbsp;encountered&nbsp;during&nbsp;simulation.<br />o&nbsp;Use&nbsp;the&nbsp;Simulation-&gtOutput&nbsp;Log&nbsp;menu&nbsp;for&nbsp;more&nbsp;information.<br /><br />而实际上Simulation-&gtOutput&nbsp;Log显示的是灰色字体,也就是在此处不可用.<br /><br />一直找不到问题所在,怀疑过license的问题,也怀疑过环境变量的设置,可是一直无法确定下来,希望在这里能遇到几个高手帮忙解决一下,感激不尽!
 楼主| song_yong 发表于 2008-7-22 11:50 | 显示全部楼层
没有人知道么?
 楼主| song_yong 发表于 2008-7-28 10:25 | 显示全部楼层
哎呀,急啊,大虾快出现阿
compassVti 发表于 2008-7-31 13:13 | 显示全部楼层
dig into its rundir
find&nbsp;its&nbsp;log&nbsp;files,&nbsp;must&nbsp;have&nbsp;detail&nbsp;infos&nbsp;there.
 楼主| song_yong 发表于 2008-7-31 15:20 | 显示全部楼层
看了log文件
详细的信息就是我前面说的那些<br />o&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;The&nbsp;netlist&nbsp;is&nbsp;up&nbsp;to&nbsp;date.<br />o&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Time&nbsp;taken&nbsp;to&nbsp;compare&nbsp;the&nbsp;design&nbsp;with&nbsp;netlist:&nbsp;&nbsp;&nbsp;1.0s<br />o&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;...successful.<br />o&nbsp;compose&nbsp;simulator&nbsp;input&nbsp;file...<br />o&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;...successful.<br />o&nbsp;start&nbsp;simulator&nbsp;if&nbsp;needed...<br />o&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;...successful.<br />
&nbsp;t<br />o&nbsp;Problems&nbsp;encountered&nbsp;during&nbsp;simulation.<br />o&nbsp;Use&nbsp;the&nbsp;Simulation-&gtOutput&nbsp;Log&nbsp;menu&nbsp;for&nbsp;more&nbsp;information.<br /><br />在没有其他的提示了<br />
